Wanted....P/S, ALT brackets, and pulleys
Old Nov 13, 2011 | 02:10 PM
Bill in NC's Avatar
Ok guys, no P/S is BS. I thought it was cool to start with, but it just sucks. The last straw was when my buddy hands me the keys to his 67 Chevelle and tells me to take it for a spin. Wow, what a difference in feel and comfort level & ability in tight parking lots.
What I need is...... well everything for my 455.
What I have now is a Mondello alternator bracket set-up (AB-499) with the 2 groove water pump and crank aluminum pulleys (2250-5089). I do not have the alternator pulley. I replaced it with a deeper groove smaller diameter pulley that allows for better charging at closer to idle speeds. If you have the parts that I need and you are interested in these parts, let me know.
What I want is restorable pieces that will look nice when blasted and painted. I will need all of the brackets, bolts, spacers, and pulleys. If it makes a difference I would like non A/C pulleys. I don't like the look of extra unused pulley grooves.
Also lead me in the right direction for a replacement P/S box. My manual box was sent out and overhauled if anyone has an interest in it.
Thanks guys
Old Nov 13, 2011 | 02:38 PM
2blu442's Avatar
I've got everything you need, but I'm out in Oregon. Shipping would add quite a bit to the price. I know there's a member in Florida with lots of spare parts, I'm drawing a blank on his name though. You might surf the parts wanted section as he's replied to several request in the last few weeks. Eightupman hasn't posted much lately, but he's in your state or the one just to your south!
Then not as close but you might try jensenracing77 and oldspackrat. J-(Chicago) has parts too, but I'm not sure he'd have the complete setup.
I've got a couple project cars with manual steering, including a 1965 442. I don't have popeye forarms and have been thinking about which way to go myself. All original or add the comforts for a daily driver. That plus power disc brakes are kinda nice to have.
Old Nov 13, 2011 | 02:56 PM
Bill in NC's Avatar
I think I may have just found someone local, but if he falls through if you have EVERYTHING, like the spacers, bolts, alt brackets, pulleys, it would probably end up costing less to ship it together than to pay shipping from several different members all over the US. If you think you do we can get on the phone and go over it all. Thanks man, I'll let you know.
I think one factor that adds to the lack of fun w/o P/S is the locker in the rear end. Tight parking lots suck lol.
Old Nov 13, 2011 | 03:20 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Send a PM to F-85 He should have the whole shebang.
I only have the power steering pump, pulley, and PS brackets from a 67'.
Old Nov 13, 2011 | 05:04 PM
L69's Avatar
L69
i got all 70-72 stuff I am in ct
Old Nov 13, 2011 | 07:17 PM
507OLDS's Avatar
I have everything,and I would be interested in your manual box.
Old Nov 16, 2011 | 05:45 PM
Bill in NC's Avatar
Guys, thank you for the responses so far. I am trying to figure out which style I can use right now to make sure I get the right style set-up. I thought this would be a little easier lol
Apparently it's a little tight on a 65 near the steering box when using the 68'+ pump bracket set-up???
Water pump shaft lengths??
Braces that run to the intake??
Old Nov 16, 2011 | 07:00 PM
507OLDS's Avatar
What is the length of the snout on the water pump,from the gasket surface to the pulley flange? You can use the AC style alternator brackets that mount on the driver's side,or the non-AC brackets that mount on the passenger side.The 68-72 style power steering assemblies can have a single-groove or 2-groove pulley.
It looks like you have the Mondello alternator bracket on there now.I was able to mount that bracket on the passenger side,by drilling one different hole in the bracket.I will try posting some pictures.All you should need is the power steering box,and the power steering pump,which I have,if you can't find down there.It also looks like you have the long-snout water pump,like the AC/heavy-duty cool applications.Same one I run,and I also have those aluminum pulleys.
Old Nov 16, 2011 | 07:22 PM
Bill in NC's Avatar
That is great info Brian! Changing the Mondello Alt brackets to the passenger side sounds good. Do you know if the 68-72 style P/S pump and brackets will clear the steering box (64-67 chassis) and would the single groove pulley line up with the first groove on the Mondello pulleys?
Alot of questions I know.....but I'm learning
Thanks for the help.
Old Nov 17, 2011 | 05:26 AM
507OLDS's Avatar
Yes,the power steering pump assembly will clear the earlier chassis,and the single-groove pulley should line up with one of the grooves on the water pump & crank.The alternator will take the other.I have the alternator up against the cylinder head,about the thickness of a nickel,for a gap.With the power steering,you might need to do one of 2 things.Either space the alternator farther out,to take the outer groove,or get a 2-groove power steering pulley,and use the outer groove on that,with the outer water & crank grooves.If I remember correctly,the single-groove power steering pump pulley uses the most inboard set of grooves.Regardless,it can be done.I've done it before with other cars.
Old Nov 20, 2011 | 05:53 PM
Bill in NC's Avatar
Picked up some parts today guys. Thank you all for the help and offers!
Old Nov 21, 2011 | 07:06 AM
ferndaleflyer's Avatar
I am in Chatham Co, NC and have a 65 parts car + a 455 or 2 with every bracket still on them + the 65 has the PS pump you need.
Old Oct 31, 2012 | 10:15 PM
batmobile67's Avatar
Question
Hey J-(Chicago),
I'm interested in your power steering pump...actually only need the pulley, part # stamped on front, either 384678 JM or 391061 JP will work. Does your pulley have either of these numbers? If so and still available, let's talk price? Know I'm responding to an old post, but please let me know either way when you get a chance...appreciate any help.
GEARMAN69
Jul 28, 2015 11:56 AM
olddaz
Aug 27, 2014 06:39 PM
Dave Siltman
Jul 24, 2014 02:55 AM
Rowdy45466
Mar 7, 2013 05:55 PM
f-85
Nov 27, 2010 05:25 AM
