Wanted - OEM distributor, and coil mount for a '70 Cutlass 350 with a 4 barrel
Old Jun 9, 2026 | 09:03 AM
Willardx1's Avatar
Ok So I am thinking of pulling the HEI the PO put in my cutlass and moving back to a points distributor and coil.
I need a good OEM points distributor and a coil mount (mine is missing). This is for a 1970 Cutlass with a 350 and 3 barrel carb, auto if that makes a difference.
While I do not want junk, I will send it in to get rebuilt.
Old Jun 9, 2026 | 09:33 AM
rhaberm's Avatar
Distributor
I have a distributor 1111961 8k31 with shaft off my 69 cutlass 350 2bbl carb and coil bracket.
Contact for pricing and shipping
Bob H. St. Louis, Mo
bestsounds2000@yahoo.com
Thank you
Old Jun 9, 2026 | 09:56 AM
Willardx1's Avatar
I will keep this in mind, further review is a 1111975 Distributor being correct for a 4bbl. that said, I doubt it will matter and it would be rebuilt for the correct engine setup.
Old Jun 9, 2026 | 02:42 PM
rhaberm's Avatar
69 AND 70 BLOCKS WERE THE SAMETO USE THE DISTRIBUTOR AND SHAFT SIZETHE SAME SPECS FOR THE USE OF EITHER DISTRIBUTOR ARE AVAILABLE, FYI
GOOD LUCK
Old Jun 9, 2026 | 03:02 PM
Willardx1's Avatar
Good to know that you. It has been a while since I owned an Olds anything. Last one was a ‘70 88 with a 455 like 30 years ago.
Old Jun 9, 2026 | 03:11 PM
Dave442's Avatar
I have several distributors, won’t be the correct numbers but will function correctly, also have the coil bracket…you can text me at (661) 203-6953. Dave
Old Jun 9, 2026 | 04:12 PM
rhaberm's Avatar
$85 WITH THE SHAFT, DO YOUNEED THE COIL BRACKET $8 PLUS SHIPPING. NEED YOUR ZIP
EMAIL ME PLEASE
THANK YOU,BOB H.
Old Jun 9, 2026 | 06:21 PM
rhaberm's Avatar
JesseOldsGuy
Jul 20, 2024 02:38 PM
jharsh
Feb 28, 2018 03:10 PM
yalikeme
Sep 10, 2015 10:27 AM
JpMotorsports
Aug 28, 2014 10:02 AM
dewcrazzy
Nov 3, 2012 07:03 AM
