Wanted - OEM distributor, and coil mount for a '70 Cutlass 350 with a 4 barrel
Ok So I am thinking of pulling the HEI the PO put in my cutlass and moving back to a points distributor and coil.
I need a good OEM points distributor and a coil mount (mine is missing). This is for a 1970 Cutlass with a 350 and 3 barrel carb, auto if that makes a difference.
While I do not want junk, I will send it in to get rebuilt.
I will keep this in mind, further review is a 1111975 Distributor being correct for a 4bbl. that said, I doubt it will matter and it would be rebuilt for the correct engine setup.
I have several distributors, won’t be the correct numbers but will function correctly, also have the coil bracket…you can text me at (661) 203-6953. Dave
