Looking for a 67 400 engine
Old Jan 13, 2025 | 06:09 AM
Stup's Avatar
Hello, new menber, first post.
figured I'd start off by reaching for the stars.
Last fall I acquired a 67 442. The original E code 400 engine got vented 45 years ago.
On the faint hope clause I'm looking for a correct engine.
I'm not stuck, I have a fresh 455 that would work.
any leads would be greatly appreciated.
Old Jan 13, 2025 | 08:36 AM
67OAI's Avatar
Old(s)GuysRule
The motor ,"E" block, except for cylinder head castings and carburetor is basically the same for years 1966 and 1967. The "C" cylinder head castings were used from 1967 thru 1969 and are still pretty plentiful. The carburetor has the number 7027156 unless it is a California smog motor which would be 7027157. Intake manifold for years 1966 and 1967 is casting number 390390 but 1968 and 1969 intakes would also work for you, they just would not have the correct casting number. Good luck!
Old Jan 13, 2025 | 08:45 AM
Moved to parts wanted
Old Jan 13, 2025 | 09:45 AM
Stup's Avatar
many thanks
Old Jan 14, 2025 | 01:35 AM
Vista67's Avatar
Where are you located?
Old Jan 14, 2025 | 02:20 AM
Rallye469's Avatar
“got vented”
Ive never heard it put that way, but i like it!
are you on FB? there’s a lot of groups that are very specific to any year you’d like. They get a lot of traffic and asking on there could be helpful as well.
Old Jan 14, 2025 | 06:32 AM
Stup's Avatar
I'm in Manitoba, but I'm not worried about doing a road trip. Even a long one
Old Jan 14, 2025 | 06:46 AM
Stup's Avatar
“got vented”
I understand Facebook is the place to be.
And I appreciate the suggestion.
But I don't do Facebook. Never have, never will.
Old Jan 14, 2025 | 07:12 AM
Core or running or built up?
Old Jan 14, 2025 | 07:57 AM
Stup's Avatar
I would consider all.
My first choice would be a running engine with compression and leakdown test. And oil pressure. (If I could afford it)
A rebuildable core would be ok. Disassembled preferred to check it out.
A bare block would be fine.
but in reality I thonk I need to be flexible. I doubt I will be flooded with a bunch of options.
Old Jan 14, 2025 | 01:07 PM
tuggy's Avatar
There was someone on facebook selling one now ad says
Came.from a 67 olds 442. It a 400 Built up motor. Have paper work with what was done to the motor and the cam card,Head work, Cammed, high volume oil pump, headers,new starter, new alt, can hear run & if you act fast enough you can go for a ride. Putting an LS in the car and also have other olds 350 parts. I do have the original intake for the 442 motor . Text Dave.7 two 4- 7 six 2-2 five 87.
https://www.facebook.com/marketplace/item/922916253285709/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A3aab980e-2a02-4209-b0a7-3d594d9e00f3
Old Jan 14, 2025 | 02:17 PM
Stup's Avatar
https://www.facebook.com/marketplace...7-3d594d9e00f3
thanks very much for the lead.
It's SOLD
Old Jan 15, 2025 | 05:52 AM
ROCKETMAN269V's Avatar
Since it obviously won't be numbers matching, have you considered a 425 engine? Looks the same; uses all the same accessories, including the flywheel/flexplate and balancer; has more power. Just a thought. I have several 425s in various states of disassembly, from bare blocks to complete engines. If interested and for pics, email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Jan 15, 2025 | 11:28 AM
Stup's Avatar
thanks for the reply Bob
I'll shoot you a email
Old Jan 15, 2025 | 11:56 AM
therobski's Avatar
The 425 is an excellent 2nd choice.
Old Jan 15, 2025 | 01:14 PM
Stup's Avatar
my car is Supreme 442 4 speed convert.
I realize it's never going to be a numbers car, but I'd like to make it as close to original as I can.. if my search for the elusive E block don't bear fruit I will have to consider other options
Old Jan 15, 2025 | 04:42 PM
Karl Mort's Avatar
E block
I'm not stuck a a, I have a fresh 455 that would work.
we
i have a spare 66 E block with other parts
where do you live?
Old Jan 15, 2025 | 06:28 PM
Stup's Avatar
Originally Posted by Karl Mort
we
where do you live?
I live in Manitoba Canada.
Were are uou located
Old Jan 15, 2025 | 06:33 PM
Andy's Avatar
Try Canadian Olds on this site, he is a Canada resident with lots of connections in Canada. May be able to help.
Old Jan 15, 2025 | 07:36 PM
Karl Mort's Avatar
Fenton Mi northwest of Detroit
Old Jan 15, 2025 | 07:57 PM
DR_DAN's Avatar
I have a nicely restored 7027157 carb I’d sell
Old Jan 16, 2025 | 04:25 AM
Karl Mort's Avatar
I live in Fenton Mi outside Detroit
Old Jan 16, 2025 | 09:46 PM
68-W46's Avatar
I have a set of correct "VG" coded "C" casting heads if correctness is an issue...
Old Jan 17, 2025 | 06:02 AM
Stup's Avatar
thanks, I'll keep it in mind
Old Jan 18, 2025 | 07:39 PM
68-W46's Avatar
Never have been machined since leaving the factory. PM if interested. They have been holding down my shed waaaay too long.
oldaman
Jun 15, 2019 02:17 PM
classicmuscle442
Dec 28, 2017 06:39 PM
Misterdog
Jan 27, 2016 04:37 PM
Oldsmaniac
Jan 17, 2015 04:51 PM
bend442
Apr 12, 2013 05:48 AM
