1989 oldsmobile ninety eight regency brougham
You can use this search engine to find Oldsmobiles in a salvage yard near you.
http://www.car-part.com/
I bet parts from a similar year 88 or even Pontiac or Buick H/C body might fit.
Good luck finding the parts you need.
Those fit the "88" up to the '99 model year. Starting around '95 or so they dropped the louvers and the panel is dead flat.
Only the right side uses the masticated rubber portion at the rear. Be careful if you remove it because they will tear.
twilightblue28A
Jun 30, 2021 09:12 AM
Bernhard
Jul 26, 2020 08:38 PM
