67 442 SS1 rims
Wasn’t aware of a factory 14 inch SS1 available thar would fit discs in 67 - Someone with more knowledge (and perhaps a PIM chart) will chime in - I thought 1969 Ly code 810 rims were the first available SS1’s that would fit discs. Now, if you wanted to go 15’s with red line radials I have a brand new set (not cheap) - only mention since I am local to you. Good luck.
Nope, no SS I's with discs in '67. If your heart's set on discs with those wheels, Wheel Vintiques or another specialty supplier is probably your best bet. Either that or scout the farthest reaches of E-bay for a set of late '69 SS I's -- IIRC there was a running change made during the model year to accommodate disc brakes. However, if you find these, they will likely be quite expensive.
Here is a SPECS excerpt. There ain't no such animal as a SSI that will work with power disc in 67. P01 was the only option for power disc brakes, and you got a special wheel that could clear them that was a stamped steel poverty cap wheel.
As said above, for factory disc on 67 to use a SSI, you need a set of any of the following:
-1969 SSI 14x6 all chrome, 810 rims
-ALL SSI 14x6 with beauty trim ring rims
-ALL SSI 14x7 1971 all chrome rims
-or any aftermarket that is advertised as fitting.
