Exhaust manifolds
Old May 5th, 2022, 09:20 AM
Johndave's Avatar
Exhaust manifolds
I am looking for both left and right side exhaust manifolds.
1966 Dynamic 88 425 single exhaust.
Johndave is offline
Old May 5th, 2022, 11:20 AM
jcdynamic88's Avatar
sorry for not getting back to you on these i've been busy,i do believe you could and should find a better right side than i have.the driver
s side i have is decent.if you find someone with a pair grab them
jcdynamic88 is offline
Old May 5th, 2022, 11:28 AM
Johndave's Avatar
I am hoping to find a decent set.....but if I can't I will get back to you for the one f you will split the set.
Will the dual manifolds fit without any modifications...
I may have to change over to duals if I have to.
Johndave is offline
Old May 5th, 2022, 12:19 PM
Oldsmaniac's Avatar
I just pulled them off a 66 98, need to give them a look and see condition. In NJ
Oldsmaniac is offline
Old May 5th, 2022, 01:17 PM
Johndave's Avatar
384784 RH384785 LHBoth have a D on them.......
that is what I have and mine are both cracked right at the dump port on the bottom side.
Johndave is offline
Old May 5th, 2022, 01:51 PM
Paladin31's Avatar
Manifolds
I have this “T” 398708 which shows to be correct for 65-68, I may have faulty info seeing your numbers off the existing manifolds
Brett
Paladin31 is offline
Old May 5th, 2022, 02:10 PM
Johndave's Avatar
That is the bad ones right there. They look close but not real sure.
Johndave is offline
Old May 6th, 2022, 05:06 AM
casting numbers aside i've found 65-74 right side manifolds from a big block 88/98 interchange
Old May 6th, 2022, 09:25 AM
72 Olds CS
RetroRanger's Avatar
Heres some at a good price
https://classicoldsmobile.com/forums...s-free-154546/
RetroRanger is offline
Old May 6th, 2022, 10:24 AM
RAG
RAG's Avatar
I have two pair, $80 for a pair plus shipping, 25 lbs. Very good condition from SW cars. rgreen@.com
RAG is offline
Old May 6th, 2022, 12:16 PM
Johndave's Avatar
I just got a set from RAG......just wanted to say thanks to everyone for the help!!
if for some reason they do not work I will be back to see what else I can find.
Thanks again
Johndave is offline
gs72
March 26th, 2022 09:45 PM
drew1987gn
March 11th, 2021 01:55 AM
GoldOlds
May 27th, 2007 01:14 PM
aristellier
January 25th, 2007 08:32 PM
Quick Reply: Exhaust manifolds
