TH 350 Detent / Kick down cable needed.
Old Jul 7, 2021 | 12:33 PM
ragtopblue's Avatar
Exclamation TH 350 Detent / Kick down cable needed.
I'm in need of an NOS or great condition Detent/Kick down cable assembly for my 1972 Cutlass Surpreme convertible. 72 has the cable from the trans to the Gas peddle. not the cable that goes from the trans to the carburetor. If I'm correct I believe the detent/Kickdown cable is the lower one. Viewing the cable location from the engine bay side of the fire wall my accelerator cable is above running to my Rochester carb.
Old Jul 7, 2021 | 12:50 PM
98 man's Avatar
Cable
I think I have a NOS one in my stuff I will check when I get home tonight
Greg
Old Jul 7, 2021 | 12:54 PM
ragtopblue's Avatar
Greg thank you so much.
I'm tired of this repro crap ! Mine is starting to corrode and the cable has started cutting into the firewall grommet. I thought it was the accelerator linkage locking up but found that was free from the carb to the the gas peddle. The noticed the kickdown cable was corroded at the firewall and it has started to saw a grove in plastic grommet.
Old Jul 7, 2021 | 06:08 PM
98 man's Avatar
Well I checked my stuff and I have a shifter cable and a speedo cable but sadly no detent cable
Sorry good luck with your search
Greg
Old Jul 7, 2021 | 07:34 PM
ragtopblue's Avatar
Ok thanks Greg.
Much appreciated ! I'd be interested in an NOS accelerator cable from the peddle to carb too if you comer across one !
Old Jul 7, 2021 | 09:03 PM
442crzy's Avatar
PM sent
Old Nov 13, 2021 | 03:40 PM
Dons70Cutlass's Avatar
Dons 70 Cutlass
Fusick kick down cable
have you looked at Fusick - search by item number TKC682
76cutlass
Apr 5, 2017 05:50 AM
88olds350
Jun 25, 2013 06:28 PM
brown7373
Mar 27, 2013 11:41 AM
Gary's 2 442-S
Oct 21, 2012 06:28 AM
805cut
Aug 31, 2012 02:03 PM
