Needed 67 Clutch Fork Pivot Grease Cup
Old Oct 12, 2020 | 05:04 AM
Oldsmaniac's Avatar
NO LONGER NEEDED>This would be the small grease cup that holds a felt washer. It rests against the pivot ball in the bell housing and the clutch fork clip slides on top. I don't know all the years Olds used this, but 66 and 67 Stick cars did. I know its not a critical part but if anyone has one let me know, Thanks!.
Old Oct 12, 2020 | 07:27 AM
My442's Avatar
My 70 has that....it is called a seal retainer.
Tough to find!
Old Oct 12, 2020 | 07:31 AM
My442's Avatar
Old Oct 12, 2020 | 11:04 AM
Oldsmaniac's Avatar
Thanks you I will make one most likely....
Old Oct 14, 2020 | 02:50 PM
deaddds's Avatar
If you get me a part number I can see if I have one nos
Old Oct 14, 2020 | 03:13 PM
Oldsmaniac's Avatar
Looks like 392336 is the steel ring (retainer) and 392335 is the ring (felt washer) TKS!
Old Oct 14, 2020 | 05:14 PM
deaddds's Avatar
No luck.
Old Oct 15, 2020 | 04:08 AM
Oldsmaniac's Avatar
No luck.
Thanks for checking.
Old Oct 15, 2020 | 08:00 AM
My442's Avatar
Take the felt ring to an electrical supply house.
They may have something close.
Or McMaster-Carr.
Old Oct 15, 2020 | 10:54 AM
Oldsmaniac's Avatar
Originally Posted by My442
Can you give inside hole size and OD and how tall it is? That will help, should be easy to recreate.
Old Oct 15, 2020 | 02:02 PM
My442's Avatar
That part is in my car now, so no dimensions.
It is a little bigger than the felt washer.
Old Oct 15, 2020 | 02:30 PM
Oldsmaniac's Avatar
Ok, I just ordered the felt washer...
Old Oct 19, 2020 | 10:44 AM
Oldsmaniac's Avatar
Ended up making one, should work. Its beefier than original but had to make due with what was on hand, Thanks.
Old Oct 19, 2020 | 03:10 PM
CRUZN 66's Avatar
Olds Fever
Nice looking work...
Old Oct 19, 2020 | 03:48 PM
Oldsmaniac's Avatar
Originally Posted by cruzn 66
nice looking work...
tks!
nelsontj
Oct 23, 2018 10:18 AM
patmills
May 3, 2015 09:56 PM
bummerino
Oct 25, 2011 08:28 AM
tecar442
Dec 6, 2010 08:34 AM
bummerino
Apr 27, 2010 08:55 PM
