Piston
Old Aug 2, 2020 | 02:40 PM
billrob71's Avatar
Piston
Know this is a long shot, looking for 1 standard bore 455 HC piston with V notch part number 398666.
I have a broken one
Old Aug 2, 2020 | 02:45 PM
billrob71's Avatar
Old Aug 2, 2020 | 05:42 PM
1970supremevert's Avatar
I have one for you
Old Aug 2, 2020 | 05:45 PM
I have 7
Old Aug 2, 2020 | 05:49 PM
Pm sent
Old Aug 2, 2020 | 07:12 PM
billrob71's Avatar
Pm back
Old Aug 3, 2020 | 05:00 AM
ROCKETMAN269V's Avatar
You may want to check the deck of your engine block adjacent to the cylinder that the broken piston came out of. If you'll notice in post #4 above, the piston has a "B" stamped in it at about the 4 0'clock position. This was done on Olds engines to denote the "relative size" of the piston. Pistons were made in A, B, C and D to accommodate minor differences in the machining of the blocks. It's a good idea to match the letter on the piston to the one on the block.
Old Aug 3, 2020 | 05:30 AM
billrob71's Avatar
Only stamp I found on it was a F
Old Aug 3, 2020 | 06:01 AM
MI68442W30's Avatar
the stamp is visible in your second picture C
Old Aug 3, 2020 | 06:44 AM
billrob71's Avatar
I’ll half to clean the top to make sure but I sure don’t see a C on my piston
can see a B on the other picture
Old Aug 3, 2020 | 08:34 AM
rocketscientis's Avatar
A pistons in A bores
Toronado being the flagship got the best of the best A bores containing A pistons....
W -30 & associated oai cars for racing lived a rougher life at higher temps & extra clearance of a size smaller piston than bore designation was SOP.
I would be shocked if I did not have piston you reqire in Lansing Michigan
Old Aug 3, 2020 | 10:46 AM
billrob71's Avatar
Ok I’ve cleaned the tops of 3 pistons and there is no stamp on the top the only stamp I have is the F for the front , part number and the GM date code
second pic is a different piston
Old Aug 3, 2020 | 10:53 AM
billrob71's Avatar
So which pistons were larger to smaller ?
Old Aug 3, 2020 | 10:57 AM
MI68442W30's Avatar
the C is clearly visible at the bottom of the picture 45 degrees from the notch on the outside of the piston not in the dished area and I can still see it faintly after being cleaned ,it is still there
Old Aug 3, 2020 | 10:59 AM
If the tops of all of your pistons look like the ones that you have posted I would seriously consider a replacement set. They appear to have suffered from detonation. Can you post a pic of the broken area on the first piston? If it came out of the engine with pieces missing between the ring lands, then you definitely have a problem. Factory high compression pistons weren't made to run with today's low octane gasoline and have a tendency to self destruct.
Old Aug 3, 2020 | 12:12 PM
billrob71's Avatar
there was a detonation problem
im putting this motor back together so I can drive my car
I’m building a 462 forge piston roller motor but want to drive the car in the mean time
the ring land was cracked and I dropped the piston and broke the side out
Old Aug 3, 2020 | 12:31 PM
Originally Posted by billrob71
there was a detonation problem...I'm putting this motor back together so I can drive my car......
The good thing is with replacement (read thicker) head gaskets, your compression ratio will drop to a more tolerable level. Good Luck with your project.
Old Aug 3, 2020 | 04:33 PM
billrob71's Avatar
Got a piston coming thank you
My question I’m staring at this piston I can not see a C on this piston , I’ve zoomed in on the picture
I can not see It
Old Jun 21, 2022 | 04:00 PM
68HurstOlds2's Avatar
C piston
Hey all,
Wanted to jump in here as I am looking for the same piston but when I tore down the engine I had 1 that was an aftermarket.
My number 3 piston clearly shows a C, but this is for the #5 cylinder.
Any help would be greatly appreciated.
Old Jun 22, 2022 | 05:38 AM
Originally Posted by 68HurstOlds2
..........My number 3 piston clearly shows a C........
The letter designation, from the factory, is stamped in the deck surface of the block adjacent to each cylinder.
Old Jun 22, 2022 | 01:14 PM
Deck Stamp
I found a CC between 1&3 a CC between 3&5 and a B between 5&7.
how do I interpret that?
Old Jun 22, 2022 | 01:38 PM
v8al's Avatar
Registered Olds Owner
See this thread: Stamp on the block deck
Old Jun 22, 2022 | 01:59 PM
I found the one for #1 with you help. My block is still stamped CC not just a single C.
Added pic. So I would need a C piston then.
Old Jun 23, 2022 | 06:32 AM
Learn something new everyday. #5 is the aftermarket piston, I will try and pull the part number from it and measure the cylinders.
Thanks for the help
yorkman
Dec 7, 2019 05:51 AM
costpenn
Feb 10, 2018 09:33 PM
STLCRZY
May 25, 2016 02:14 PM
Magna86
May 29, 2014 07:55 PM
Shanghai Smith
Jun 19, 2013 02:32 PM
