Wanted 455 engine for a 1971 Cut
Old Feb 24, 2020 | 02:25 PM
Powerm01's Avatar
Ok. Finally the time to upgrade my 350 to a 455. I live in the Detroit area. Does not have to be whole engine. Could just be block maybe heads. I might wanna build some of it myself. Do I have to change the motor mounts?
Thank you Michael
Old Feb 24, 2020 | 03:48 PM
jmos4's Avatar
Hi,
There's a few on craigslist, DetroitandFlint, think there is also a 72 motorhome with a 455 in it as well
regards,
Old Feb 24, 2020 | 03:59 PM
cman442's Avatar
Yes have to change motor mounts
Old Feb 24, 2020 | 06:16 PM
I don't think that is accurate. From what I recall, if you match the engine and frame mounts, as in in if you use the SBO engine mounts with the SBO frame mounts, or BBO engine mounts with BBO frame mounts, the engine will sit in the correct orientation.
So if you are installing a 455 in place of a 350, use the 350 mounts.
Old Feb 25, 2020 | 09:46 AM
deadeyejedi's Avatar
I agree bolt the 350 mounts to the 455
Old Feb 26, 2020 | 06:37 AM
Rusty Boltz's Avatar
Not close to you, but I have a pretty much complet4 1970 455 removed from a Toronado GT w-34 car that I have had sitting in my garage for about 22 years. Includes some extra parts also. This motor has the large valve heads and was factory rated at 400 HP. Located in the Reno, Nevada area.
Last edited by Rusty Boltz; Feb 26, 2020 at 06:41 AM. Reason: adding omportant details
Old Feb 29, 2020 | 05:08 AM
Charlie_brown's Avatar
455
I've got one worked from top to bottom if you're interested. 455 +.30, c heads, keith black forge pistons, xe284h comp cam. Milodan 1/4in+ oil pan, oil restrictor. Theres plenty more if you're interested. I'm in north florida.
Old Mar 6, 2020 | 09:36 AM
rocketscientis's Avatar
Almost a few in your back yard
Lansing Michigan to be more presice
entire enines or individual pieces
Do you know what heads you want ??
2 big valve 70 Toros engines and those where reported to have more horsepower in the 70 W 30
Old Mar 14, 2020 | 10:18 AM
Nikkor's Avatar
If you haven't found a 455 block or engine yet I have four 1970 455s.
Two are near complete, pretty much just missing the carburetors: One is a "Serf F block" with E heads that I pulled from a Linden, NJ built 1970 442. The other is a "Stick F block" with E heads out of a big body Fairfax, KS built car.
I also have 2 bare 1970 455 blocks. Both are "Stick F blocks" out of Lansing built cars...one of them I personally removed from a 1970 442.
Also have two 455 crankshafts available along with lots of other 1970 -1972 455 engine and Cutlass/442 parts.
PM me if interested.
Wyocutlass71
Aug 31, 2017 07:00 PM
Powerm01
Jun 5, 2017 12:29 PM
75cutty455
May 13, 2015 04:50 AM
70sx455
Jun 25, 2014 10:51 AM
