1961-63 f85 cutlass convertible fenders and door
Old July 21st, 2019, 05:21 AM
djboz's Avatar
i am looking for a passengers side door (prefer complete with window assembly) and both front fenders for a 1962 Oldsmobile F85 Cutlass convertible.
I would appreciate any thing you have or have leads on.
Dan
djboz is offline
Old July 21st, 2019, 05:55 AM
FYI, the 63 sheet metal is completely different from the 61-62 parts. Also, as you probably know, only the Cutlass convertible and Jetfire doors are compatible. To open your search a little, Buick DID make Skylark hardtops and those doors also interchange for 61-62. The Tempest convertible doors should also interchange. Good luck.
joe_padavano is offline
Old September 19th, 2019, 02:10 AM
rocketscientis's Avatar
61-2 f-85 parts car
Plz cal or txt contact info to 9897219432 & i will send u pix of pcs u need
Thanke
Fon /email
rocketscientis is offline
Old September 20th, 2019, 09:59 AM
Daiv8or's Avatar
I have wondered about the interchangeability of BOP Y body doors. Other then trim, they do all look the same. I also recently discovered that apparently, the Pontiac deck lid, while styled different, will fit on an Olds. What I don't understand is, why the Olds convertible and Jetfire doors interchange, but not the Cutlass hardtop? From a manufacturing stand point, that makes zero sense to me.
Daiv8or is offline
Old September 20th, 2019, 10:20 AM
There is no such thing as a 1961-63 Cutlass hardtop. The only Y-body hardtops built by Olds were the 62-63 Jetfires. All other Cutlass 2drs in those years were Sport Coupes. As I pointed out in Post #2, Buick DID make Skylark hardtops.
Old September 20th, 2019, 11:57 AM
Daiv8or's Avatar
Ah... I see now. I had assumed the stainless frames on the Cutlass rolled down like the convertible to make a hardtop, but on examination, my assumption was wrong. Cutlasses of this era are post cars. Once again I learn. Still in a pinch, I wonder if a person could use the door from a coupe on a convertible by cutting and modifying? It would probably be a lot of work though.
Daiv8or is offline
Old September 29th, 2019, 04:15 PM
bigdooly's Avatar
Try this guy, Dave 570 798 0390
Has lots of parts cars
bigdooly is offline
Old September 30th, 2019, 12:09 AM
Early f-85 doors
Certainly it will be a fair amount of work ..as long as your comfortable with your level of skills & abilities or $ bodyman eztimates....compair that to availability & posability of gettin exactly what u need compaired to whats available.....made a rear sway bar for 68 - 72 B bodiez while back cause theres none to b found...n its very likely I will b doin it for sumone again here shortly...I hav to work with what i got
I hope you r able to get u sumthin you can work with
Was not aware of that & is good to know...thanks 4 input
painterbrad
April 20th, 2014 11:03 AM
doctorolds
June 30th, 2013 12:37 PM
L&L Auto Restorations
July 11th, 2012 04:58 PM
sbaumer2
April 5th, 2012 06:44 PM
70redvert
March 31st, 2009 05:35 AM
Quick Reply: 1961-63 f85 cutlass convertible fenders and door
