Wanted 7040250 Carb
Old August 26th, 2018, 01:52 AM
Del70's Avatar
Wanted 7040250 Carb
Looking for a 70 350 A/T 7040250 factory Carb. Working, but may need to be rebuilt (need typ. gaskets etc is fine). Please send PM with pictures, price. thanks
Del70 is offline
Old August 26th, 2018, 07:25 AM
DLP
DLP's Avatar
carb wanted
I do have a 7040250 carb.
It was on a 455.
The air horn started leaking (probably due to warpage.
The carb otherwise worked fine.
It'll more than likely need a rebuild since it's been sitting in a box for so long.
It's NOT a restamp.
I'm located in the Minneapolis Minnesota area.
Let me know if you are interested...
DLP
DLP is offline
Old August 26th, 2018, 08:55 AM
Del70's Avatar
No thanks - Do not want one with leaks/with a warped air horn. - thanks again.
Del70 is offline
Old August 26th, 2018, 09:03 AM
DLP
DLP's Avatar
Oh well,
It was worth a shot...
DLP is offline
Old August 27th, 2018, 09:56 AM
Del70's Avatar
All set - thanks
Del70 is offline
Old August 28th, 2018, 09:29 PM
teamwieland's Avatar
Quadrajet
I have a 7040251 or 704025L (hard to make out the last digit). Just pulled it off my '70 455. I am in Colorado springs and the carb was set up for lower elevation so I put an Edelbrock on that was already set up for the thin air.
teamwieland is offline
Old August 29th, 2018, 02:32 AM
jollyolds's Avatar
7040251 was a big car carb with 455-not 442
jollyolds is offline
Old September 2nd, 2018, 06:53 PM
Quadrajet Power's Avatar
We have some 7040250 available if you still need one. We build to order so it would typically take 3 weeks for the restoration.
Quadrajet Power is offline
Old September 5th, 2018, 02:41 AM
Del70's Avatar
Do your carbs carbs have the correct part number throttle body for the 7040250 carb?
thanks
Del70 is offline
Old September 5th, 2018, 05:45 AM
I will double check the stamp to verify. Most of our cores we have are original take offs that we build from. Some have been rebuilt somewhere years ago, but we also have several hundred extra throttle bodies for spares and parts.
rand5204
December 10th, 2018 09:07 PM
69442murph
June 18th, 2014 04:28 AM
JOHNNYOLDS442
August 2nd, 2012 08:51 AM
JOHNNYOLDS442
June 25th, 2012 11:17 AM
dannymoz71
June 29th, 2010 10:37 PM
Quick Reply: Wanted 7040250 Carb
