Wanted 7040250 Carb
carb wanted
I do have a 7040250 carb.
It was on a 455.
The air horn started leaking (probably due to warpage.
The carb otherwise worked fine.
It'll more than likely need a rebuild since it's been sitting in a box for so long.
It's NOT a restamp.
I'm located in the Minneapolis Minnesota area.
Let me know if you are interested...
DLP
It was on a 455.
It's NOT a restamp.
DLP
Quadrajet
I have a 7040251 or 704025L (hard to make out the last digit). Just pulled it off my '70 455. I am in Colorado springs and the carb was set up for lower elevation so I put an Edelbrock on that was already set up for the thin air.
I will double check the stamp to verify. Most of our cores we have are original take offs that we build from. Some have been rebuilt somewhere years ago, but we also have several hundred extra throttle bodies for spares and parts.
