61-63 4 speed shift lever
Old Jan 19, 2017 | 04:15 PM
jensenracing77's Avatar
I have had a change of plans from my last post. Now I am looking for a 61-63 4 speed shift lever from a Cutlass or Jetfire. Would even take one from a Buick. Don't need the shifter, just the chrome lever that sticks up through the floor. Any condition.
Old Jan 19, 2017 | 04:57 PM
Ancient Iron's Avatar
The shift lever doesn't detach from the shifter box like a Hurst, It is integral.
Old Jan 19, 2017 | 06:03 PM
The shifter has to come apart. I don't need the very bottom part. I am going to cut and weld on it. I am a purist and can't believe I am looking at doing this but.... I think I am going to swap the factory shifter with a Hurst shifter. I want an original shift lever to cut and weld to the bottom of a Hurst lever. This way it will look original from the interior. I don't want to cut and weld my original lever because I would like to be able to swap it back someday if I ever do a concourse restoration.
Old Jan 19, 2017 | 06:53 PM
Charlie Jones's Avatar
Phantom Phixer
Would this one do ?
http://www.lategreatchevy.com/full-s...urst-1963.html
Bolts right up to a Hurst competion plus shifter . Looks like a "spaghetti Shifter " handle ,
Old Jan 19, 2017 | 06:58 PM
Would this one do ?
That one is a little off but may work. I think this one is very close. I may consider this till I can modify an original. http://www.ebay.com/itm/301451011239
Old Jan 19, 2017 | 09:18 PM
Yes it comes apart, But why go through all that trouble. I would save the original and buy the Hurst lever and a competition box and bolt it together It looks close and only a purist like me would know it's not original(I own a 63 4 speed convertible) Trust me the factory shifter is kind of sloppy, A new Hurst with the correct spring clips on the linkage and it will shift like a million dollars
Rocketbrian
Oct 2, 2013 10:18 AM
1965F85_scholten
Sep 22, 2013 07:00 AM
dmberendsen
Apr 10, 2013 03:18 PM
Alocatelli
Dec 10, 2012 07:49 AM
Flye
Apr 18, 2011 04:24 PM
