Bell housing for 394...
http://www.speedwaymotors.com/Shop/1...usings/85.html
Here's one. Internet search will probably get you a dozen other sites
Probably 3/4 of the rear of the block IS the housing. A fairly thick and heavy lower section with the peep cover plate is the other part. That I have if we are on the same page. If you are looking to update to another trans I believe someone makes an adapter plate to bolt to the rear and to hook up a later trans.
Unless the OP wants to put a manual transmission in his car. Then he'd need something like the one on oldspackrat's thread:
https://classicoldsmobile.com/forums...8-4-speed.html
Try Ross Racing they make a adapter along with others.... Tedd
https://rossracingengines.oursafeserver.com/
