Bell housing for 394...
Old Feb 14, 2016 | 09:07 AM
markmag's Avatar
bell housing for my '63-88,,,394..
Old Feb 14, 2016 | 10:46 AM
TripDeuces's Avatar
http://www.speedwaymotors.com/Shop/1...usings/85.html
Here's one. Internet search will probably get you a dozen other sites
Old Feb 15, 2016 | 04:30 AM
deaddds's Avatar
I will try to look today but thought it was part of the casting of the block and just the lower section was detachable to where the trans bolts up.
Old Feb 15, 2016 | 06:54 AM
wr1970's Avatar
x2 that is the way the one on the engine run stand is in the garage.HMM
Old Feb 15, 2016 | 09:59 AM
Run to Rund's Avatar
The QT 8070 is for the late 330-455 engines.
Old Feb 15, 2016 | 03:07 PM
deaddds's Avatar
Probably 3/4 of the rear of the block IS the housing. A fairly thick and heavy lower section with the peep cover plate is the other part. That I have if we are on the same page. If you are looking to update to another trans I believe someone makes an adapter plate to bolt to the rear and to hook up a later trans.
Old Feb 15, 2016 | 03:56 PM
wr1970's Avatar
^^^^^this.
Old Feb 15, 2016 | 05:49 PM
2blu442's Avatar
Unless the OP wants to put a manual transmission in his car. Then he'd need something like the one on oldspackrat's thread:
https://classicoldsmobile.com/forums...8-4-speed.html
Old Feb 15, 2016 | 05:53 PM
Tedd Thompson's Avatar
Try Ross Racing they make a adapter along with others.... Tedd
https://rossracingengines.oursafeserver.com/
Old Feb 16, 2016 | 02:00 PM
D. Yaros's Avatar
This is the bell housing from a 1960 394. I know not if/how much the housing may have changed in later years?
Old Feb 16, 2016 | 06:59 PM
wr1970's Avatar
Ah thanks for showing these pics. Might be what the op is looking on a 63! I wonder what year they changed?
Old Feb 17, 2016 | 05:07 PM
deaddds's Avatar
Definately different for 63/4. Not sure about 61/2 but expect them to be the same.
Old Feb 19, 2016 | 04:27 AM
deaddds's Avatar
I'm guessing you don't really need one now?
jensenracing77
Dec 20, 2022 12:37 PM
mono-plane
Oct 15, 2009 04:40 PM
silverriff
Nov 17, 2008 06:29 PM
dan2286
Jul 26, 2008 05:00 PM
ozoneblue
Aug 21, 2007 05:59 PM
