WTB Z bar (cross shaft, equalizer) for 1966
I am in need of an original Z bar (cross shaft, equalizer) in good condition for 1966 V8 Cutlass, F85 , 442. Looking for the one with the formed sheet metal arms.
I have one that is worn through @ the clutch adjusting rod hole. It can be repaired as they all wear but this one wore completely through. I also have a new upper bushing for it. I can repair it or you can save some $$$$ and do it yourself. Contact me at pchopesq@aol.com
The one I need does not have the bushing. I believe the bushing is used on 70-72 and that z-bar has more of a bend on the pedal arm. I have one of those and it 's not going to work on the 66.
Thank you.
Thank you.
I guarantee you that a 66 Z-Bar uses a rubber steel sleeved bushing where the clutch rod attaches.
Thanks for the reponses.If the one in the above photo is the correct one then I need the upper rod also. The rods I have do not have a long enough pin to make it thru the bushing. so I would need both pieces. The z-bar I have does have more bend to the arm than the one above.
Jim parts went out today Thanks if we can help just let us know rocketrat442@yahoo.com
bronze66f85
December 8th, 2014 12:40 PM
ROCKET VAPOR
June 20th, 2011 06:50 PM
