WTB Z bar (cross shaft, equalizer) for 1966
Old Dec 11, 2014 | 04:00 PM
bronze66f85's Avatar
I am in need of an original Z bar (cross shaft, equalizer) in good condition for 1966 V8 Cutlass, F85 , 442. Looking for the one with the formed sheet metal arms.
Old Dec 18, 2014 | 05:52 AM
Ttt
Old Dec 18, 2014 | 08:06 AM
fast67vellen2o's Avatar
Do you have a photo of one so I can see if I have it? I have a boatload of Z bars here.
Old Dec 18, 2014 | 06:25 PM
I hopefully attached a page from the assembly manual.
Old Dec 19, 2014 | 03:09 AM
66-3X2 442's Avatar
I have one that is worn through @ the clutch adjusting rod hole. It can be repaired as they all wear but this one wore completely through. I also have a new upper bushing for it. I can repair it or you can save some $$$$ and do it yourself. Contact me at pchopesq@aol.com
Old Dec 19, 2014 | 04:40 AM
The one I need does not have the bushing. I believe the bushing is used on 70-72 and that z-bar has more of a bend on the pedal arm. I have one of those and it 's not going to work on the 66.
Thank you.
Old Dec 19, 2014 | 06:09 AM
slaughter442's Avatar
Thank you.
We have one from a 66 4 speed car and other 4 speed parts if we can let us know Thanks Darren rocketrat442@yahoo.com
Old Dec 19, 2014 | 08:12 AM
66-3X2 442's Avatar
Thank you.
I guarantee you that a 66 Z-Bar uses a rubber steel sleeved bushing where the clutch rod attaches.
Old Dec 19, 2014 | 09:06 AM
Thanks for the reponses.If the one in the above photo is the correct one then I need the upper rod also. The rods I have do not have a long enough pin to make it thru the bushing. so I would need both pieces. The z-bar I have does have more bend to the arm than the one above.
Old Dec 19, 2014 | 03:22 PM
Here is the photo of the 66 rod Thanks Darren
Old Dec 30, 2014 | 02:40 PM
Jim parts went out today Thanks if we can help just let us know rocketrat442@yahoo.com
Old Jan 2, 2015 | 03:56 PM
Still need a 66 (64?,65?,66) upper clutch rod as in the photos above.
Suede53
Jun 24, 2016 06:35 AM
bronze66f85
Dec 8, 2014 12:40 PM
rvandeven
Aug 18, 2014 01:35 PM
highschoololds
Mar 2, 2012 06:19 AM
ROCKET VAPOR
Jun 20, 2011 06:50 PM
