WTB disc brake prop valve
anybody have a disc brake p-valve they will part with for a 72 Cutlass? I pulled rotors and spindles off a parts car i had, but wasn't smart enough to save the p-valve before it went to the shredder. thanks Chad
You may want to consider a new brass one, available just about everywhere now. The original cast iron combo valves often get rust in the bore, which can cause the differential pressure switch to stick on one side when bleeding the brakes.
Curts1970cutlass
Brakes/Hydraulic Systems
September 26th, 2014 12:08 PM
dgy
April 6th, 2012 11:03 AM
