wtb 1971 cutlass 442 HD radiator
Old Apr 26, 2011 | 07:55 AM
leepear's Avatar
I am looking for the correct passenger side radiator tank (radiator cap side, stick shift if possible) for my 1971 442 with HD cooling and fan shroud. Will purchase entire radiator or just the tanks for a recore. Tanks Lee
1970 442
1971 442
1970 vista
Old Apr 26, 2011 | 08:09 AM
GAOldsman's Avatar
"Car"mudgeon
Here is some info from 442.com classifieds with a guy that has a 4 core radiator, not sure year or code but it may be worth a try.
ros6872@hotmail.com 203-272-7103 Meriden CT
Scot
Old Apr 26, 2011 | 08:28 AM
leepear's Avatar
Thanks Scot for your help. I should have thought of that. I am not sure what to look for yet except have been given the correct code.
Lee
Old Apr 26, 2011 | 08:41 AM
GAOldsman's Avatar
"Car"mudgeon
Lee No problem. Love your car, I wish I could see that thing at the Olds Nationals, but I can't make that trek. I know you are trying to keep it as correct as possible. Finding "THE" code correct one will be a treasure hunt to say the least. I would shoot for at minimum a 4 speed radiator from any 70-72 GM A-body. Just until you locate "THE" one. Just my opinion. Good luck. And I will keep my eyes peeled.
Scot
Old Apr 27, 2011 | 05:22 AM
507OLDS's Avatar
The tanks on my stick-shift cars still have the ports for the auto trans cooler,but there are a flush-style,flat plug in them.They are different sizes between 70 and 71-72.You are also looking for a tank that says Harrison up near the neck.
Old May 7, 2011 | 02:48 PM
seymog's Avatar
1971 GP Harrison radiator
Hi Lee,saw your post and may have a radiator you could use.First it is out of a 71 Pontiac Grand prix 29 x 18 1/2 x 2 3/4 core size,it says Harrison by the top inlet,but it doe's have the holes in the tank for automatic trans lines and it is a 4 core. I also have it listed this week on Ebay listing # 330560562299 if you want to check that out.I have it listed for $75.00 + shipping which won't be horrible since I am in Nevada,but also if it sells on Ebay you are out of luck.So if interested please feel free to contact me direct at seymog@netscape.com,thanks Gary
Old May 7, 2011 | 04:08 PM
2blu442's Avatar
I've got some 4 row harrison tanks but I believe most have the upper transmission coolant line close to the top. I believe the A body cars had it down lower. I'll check, if you would accept the correct looking tank that may or may not have the correct code stamped in it I may be able to help. John
Old May 7, 2011 | 04:50 PM
driverchoice's Avatar
i was told both are correct w/,w/o trans cooler it could have came both ways from factory, also you have to be carefull as the tanks have letters that correspond with the tag that was on the rad, pontiac does not interchange w/olds found this out when i was going to use a pontiac blank tank for my olds
Old May 8, 2011 | 09:59 PM
leepear's Avatar
Thanks for all your help. The radiator is for a very nice 1971 w-30 that I am trying to keep as original as possible. I would like to find the correct code tank because I was told all heavy duty cooling in 1971 used the same radiator. So a cutlass with ac and heavy duty cooling would be correct too. My original has been repaired once and needs more repairs so I am calling it junk and trying to find an original tank or radiator. The Grand Prix probably wont work but I appreciate you contacting me.
Lee
Old Dec 13, 2011 | 07:44 PM
leepear's Avatar
I am still looking for this correct Harrison four row radiator or tank side with with the cap for my 1971 442. I currently have a made in mexico radiator in my very original car and am anxious to make it right again. Someone must need some Christmas money.
Lee
Old Mar 6, 2012 | 06:47 PM
leepear's Avatar
Still looking for the tank here is a picture of why I need one. It also answers the question why don't I fix my old tank........Lee
Old Mar 6, 2012 | 11:56 PM
Mr Shifty Sidney's Avatar
Lee,
Are you looking for a tank with the correct code? If so, are you sure a Cutlass with ac and heavy duty cooling would be the same? The 71 assembly manual designates a different radiator assembly for a 442 with 3.73 gears and Cutlass with ac and heavy duty cooling. I guess the passenger side tank could be common. Do you still have the original metal tag from your radiator? What code is it? What code is stamped on the tank you need? I am assuming your car is a 71 W-30 4 speed with 3:73 gears.
Don W
Old Mar 7, 2012 | 06:08 AM
leepear's Avatar
Mine is a 342 ss tag 3017258
Lee
Old Mar 7, 2012 | 07:42 AM
11971four4two's Avatar
MOTORHEAD
Hi Lee
Rocket Vapor has info on the rad tanks in the thread link below. Maybe he can let you know which embossed letters you need
https://classicoldsmobile.com/forums...71-w-30-a.html
Alex72cutty
Apr 21, 2015 10:30 AM
Blackpage
Feb 7, 2012 07:49 AM
leepear
Apr 25, 2011 04:52 PM
RPD1659
May 21, 2008 06:55 PM
