1971 442 w-30 convt 4 speed radiator
No it is not for sale. I brought it out of storage last week and a friend helped make a list of things that are incorrect on the car. It was not as bad as I expected. Things like license plate screw kit, rear trunk moulding screw plastic washers, one trunk bumper, one door bumper, exhaust locks, etc.
I don't believe the car has the original radiator and it is leaking at one of the plugs to the trans cooler welds. Instead of fixing the old incorrect tank I would like to find the correct tank for the car. I posted a picture of what I have and would appreciated if someone would let me know if it is the correct tank. If not I would like to have a correct tank installed. Let me know if you have any in your parts piles and price. You need to know that it is a 1971 w-30 4 speed with 3:42 posi. It currently has a fan shroud and 4 row radiator. Not sure if that is correct either. I may have installed the radiator years ago but cannot remember what I originally had 25 years ago.
Thanks Lee
1970 442
1971 442
1970 vista cruiser
Thanks Lee
1970 442
1971 442
1970 vista cruiser
The '71 A-body with heavy duty cooling and 3.42:1 axle should be an S S for the two letter code per the assembly manual.
http://wildaboutcarsonline.com/membe...Section_6D.pdf
http://www.gmheritagecenter.com/gm-h...2_Info_Kit.pdf
S S code Olds part # 3017258
Good luck finding one Lee
Scot
Scot
this is my 71 not the 70. The 70 had the original radiator so that part of the restoration was easy except the $800 to restore the radiator. The 71 was purchased in New York and brought to California in about 1973. If you look at the picture it has had a repair or something right where the numbers are on the vista.
Lee
Lee
looks like the fill tube was repaired too, should have some stamps on it - if not probably not original the 71s and 72s had a filler tube that was more on a 30 degree angle the 70s were parallel to the ground like the one you have
