wtb 1970 455 Fan shroud
Old Feb 12, 2017 | 12:24 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
yes a fan shroud mine is missing?
Old Feb 12, 2017 | 08:57 AM
junior supercar's Avatar
on the agean car you just bought (educated guess since I saw the other thread)? if so, it's no supposed to have one. Look at the bottom of the radiator core support. There won't be any tabs to mount the lower portion of the fan shroud.
Old Feb 13, 2017 | 01:09 PM
jensenracing77's Avatar
x2 but if you want to add one I should have one.
Old Feb 13, 2017 | 10:05 PM
Olds Specialist LOL
Are you guys serious? it dosnt come stock with a shroud? i know my 71 442 had one???
Old Feb 14, 2017 | 02:15 AM
442Fred's Avatar
If it doesn't have the tabs for a shroud then on the bottom of the core support it probably didn't have one from the factory.
Old Feb 14, 2017 | 04:32 PM
kevdog442's Avatar
Member
I know some cars didn't come with one, I've even had one, but what was the reasoning for not throwing in a piece of plastic that could only make it more efficient? I doubt if they were really saving much money.
Old Feb 14, 2017 | 08:42 PM
Olds Specialist LOL
It looks like my top Radiator plate is further towards the fan more than one with a shroud
Old Feb 14, 2017 | 09:18 PM
70Post's Avatar
your top plate isn't designed to use a fan shroud....it's the version Olds installed on the '70 Abodies that didn't have one.
It doesn't even have the holes in it for the upper fan shroud mounting points.
It's correct for your car as the car appears now.....non-ac, non HD cooling, 3 row radiator setup.
Old Feb 15, 2017 | 01:50 AM
Olds Specialist LOL
I can think the build sheet said heavy duty cooling?
OTE=70Post;991485]your top plate isn't designed to use a fan shroud....it's the version Olds installed on the '70 Abodies that didn't have one.
It's correct for your car as the car appears now.....non-ac, non HD cooling, 3 row radiator setup.[/QUOTE]
Bee Saint Louis
Apr 13, 2025 08:28 AM
shamusj
Jan 13, 2015 05:44 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
