Wanted: 84 Charcoal Canister mounting clips
Old Sep 16, 2021 | 08:38 PM
fjwhoopie's Avatar
I need the mounting clips / hardware for the charcoal / vapor canister on the passenger fender well, Thanks
Old Sep 17, 2021 | 04:19 AM
69HO43's Avatar
You'd be searching for TWO of GM p/n 554665 clips. These were actually made as tubing clips per the standard parts description, but GM mostly used them to clip into the bottom of the vapor canisters to hold them down. If you have to do a junkyard crawl, they're found on B, C, D, E, and G bodies of the 1980s, and even into the early 90s on some.
Additionally, you'll need 2 bolts with SEMS hex w/flange washers to hold them onto the fenderwell. GM p/n 12337828 is the last good number out of a string of supersessions. M6.3 x 1.81 x 20 shows in the parts catalog.
Summit is just one place that sells the bolts online, but they should be available at your local dealership for $1.08 each list price. Less if you get a discount.
Chevrolet Performance 12337828 Chevrolet Performance Replacement Screws | Summit Racing
78Cutlass4Speed
Apr 2, 2019 05:39 PM
brichar8
Ninety-Eight
Sep 17, 2015 01:20 PM
autocomman
Sep 16, 2015 12:51 PM
Rocket331
Body work
Sep 18, 2012 04:00 PM
ctrain22
Body work
Jul 29, 2010 12:26 PM
