tilt column
Old May 31, 2025 | 04:16 PM
servexcell's Avatar
tilt column
looking for a tilt column for a 68 Cutlass
Old Jun 4, 2025 | 06:55 PM
oldolds88's Avatar
floor shift or column?
Old Jun 4, 2025 | 09:48 PM
servexcell's Avatar
column
thanks
Old Jun 7, 2025 | 09:11 PM
joes_olds's Avatar
Originally Posted by 66luvr
Would a 66 tilt column fit?
I have one of those I would sell.
I believe the 68 is one year only column. Not 100% on that though. It also has the ignition on the dash and not the column. Does a 66 have the same setup? I think for column swaps the main things are length and the of splines on the shaft. The more variation, the more customizing you need.
Old Jun 8, 2025 | 07:43 AM
ROCKETMAN269V's Avatar
Originally Posted by joes_olds
............. It also has the ignition on the dash and not the column. Does a 66 have the same setup?............
All, up to and including 1968, had the key in the dash. Federal law mandated locking steering columns in 1969 to help curb vehicle theft, although, for some reason, it didn't apply to vans.
Old Jun 8, 2025 | 11:59 AM
Loaded68W34's Avatar
68 is 1 year only, but similar to 67. 67 was the first year for 4-way flashers in the column. So starting in 67, the column diameter at the steering wheel got slightly larger. 67 has a 1-piece colapsable steering shaft running from the steering box to the steering wheel. The 68 column is like the later 69-72 columns with a steering shaft running from the steering box to a u-joint at the bottom of the steering column. Then a seperate shaft in the column itself. The column for your car should interchage with other 68 BOP tilt columns. 66, 67, and 68 chevelle tilt columns are all 1 year only 1 model only columns (they need to come from that year chevelle and will not correctly interchange with BOP) because of how they meet the dash.
Old Jun 8, 2025 | 07:48 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I installed an Ididit tilt column in the Vette, Its a one year wonder 68 as well. The Ididit is high quality and went in without a hitch, plug n play.
Good luck finding a 68 A body Olds OEM tilt, column or floor shift. If you do locate one you could've bought 3-4 Ididits.
Take a look at the site or call. Flaming River is supposed to be the same.
Old Aug 14, 2025 | 05:22 PM
servexcell's Avatar
do you have a floor shift one
Old Aug 14, 2025 | 08:01 PM
marxjunk's Avatar
No..
Old Aug 14, 2025 | 08:08 PM
marxjunk's Avatar
I dunno the confusion there's 2 posts blah blah..so I'm out..mine is no longer for sale
kbdecatur
Aug 14, 2025 05:20 PM
dbater
Feb 17, 2021 06:56 AM
starfire
Jul 14, 2013 04:21 PM
charlierogers
May 1, 2011 03:21 PM
1968Cutlassfallbrook
Apr 30, 2011 02:24 PM
