Th350 or TH400
Old May 3, 2012 | 11:37 AM
Doomah's Avatar
Th350 or TH400
I am looking for a TH350 or TH400 in the new york area, I would like one that is working but I would think about a Core. Thanks!
Old May 3, 2012 | 11:57 AM
droptopron's Avatar
delete
http://newyork.craigslist.org/lgi/pts/2966731912.html
http://longisland.craigslist.org/pts/2927676222.html
When calling do NOT ASK "will this fit a '69 Cutlass". They will invariably say yes. Ask what it came out of. Chevy has a different bolt pattern that Buick/Olds/Pontiac. Some units have both patterns. There is also long tail & short tail. I believe a long tail can be made to work with a custom drive shaft but a short tail would have come with your car. JMO but I think you are better off finding a core and having it gobe thru rather than buying a used one that the seller says is good.
Old May 3, 2012 | 12:43 PM
74 Omega's Avatar
Still got this one....NH
https://classicoldsmobile.com/forums...tml#post400289
Not too far away....pretty much a core price right there...
$75 for the convertor and I'll give you the transmission.....
Last edited by 74 Omega; May 3, 2012 at 12:46 PM. Reason: added last line....but you got to take em both.
Old May 3, 2012 | 01:01 PM
Doomah's Avatar
I think I found a Th400 that is working it is from a shop he wants 400 for it, it came out of a 1985 cutlass will that make it fit any better?
Old May 3, 2012 | 01:31 PM
Eddie Hansen's Avatar
jp, you will also need to ask if someone has a drive shaft and a yoke for a 68-69 with turbo 400.... I say 68-69 because I think you probably have4 an O type rear, and I am unsure if all 70-72 had them, I don't think so.
Old May 3, 2012 | 05:37 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
There was no th400 available in an 85 cutlass.
I have a rebuilt th350 here in great shape if you are open to shipping. Not a "craigslist rebuilt" trans. An actual rebuilt trans I will warranty.
Old May 4, 2012 | 06:35 AM
507OLDS's Avatar
Make sure it's a short-shaft TH400 too.The long-shafts from the big cars can be converted,but it involves taking the trans apart.
Old May 4, 2012 | 06:44 AM
Doomah's Avatar
Hmm that scares me now, Guy said he got it out of a 1985 cutlass and it is TH400 and J(chicago) says they didn't come with a TH400 I'm not saying the guy is lieing but now it sound fishy, when I look at the TH400 I can tell if it is a real TH400 BOP? Plus anyway to tell if it is in good working order? Myabe it came out of a diff car or maybe the guy who own the cutlass did a swap him self?
I would buy the TH350 rebuilt you have J(chicago) but last time I look at shipping for a tranny it was 500 just to ship :P
Old May 4, 2012 | 06:55 AM
507OLDS's Avatar
I've shipped transmissions,and it should cost less than that.I have a few TH350's,but no extra TH400's right now.
Old May 4, 2012 | 07:21 AM
rustyroger's Avatar
'87 Delta 88 Royale
The 85 Cutlass wouldn't have left the factory with it, but it might have been put in with a bigger engine as a modification at a later date.
The more I found out about automatic transmissions the more I realise I don't know, but it seems there are a lot of variables with tailshaft length and bolt pattern. I have been told by experts that the internals can vary as well. IMO you should have your own unit overhauled by a reputable shop, you know yours is the right one.
Roger.
Old May 4, 2012 | 08:15 AM
JP, I seriously think you would be fine with a turbo 350, think about it, find one that works, and someone will stand behind. ( both J-chitown and 507 ( Brian) have EXCELLENT reputations, brian is in Pennsy... so get to the Verazano, over the Goethels, and on to Pa... , or ask J what the shipping would be... you get to use the yoke, driveshaft etc etc from your power "slide" etc... then when and if you build your next engine, you can either upgrade to an overdrive, have the turbo 350 beefed up, or sell the turbo 350 and and have a new turbo 400 built.
this will be a very nice upgrade, your getting it from a relaible source(s), reduces your costs by reusing your yoke, drive shaft etc... it takes some decent change to get a built motor, even a semi stocker like mine, so it is better to do it in steps....
Old May 4, 2012 | 08:37 AM
buy from someone you know or is known....
JP I still think it best to buy from someone that you know or known, instead of strangers ( hmmm wait we are all strangers or at least strange)
here are some finds from central jersey
this is a short tail shaft
http://cnj.craigslist.org/pts/2931930369.html
no real info on this one
http://cnj.craigslist.org/pts/2964964844.html
found this while looking LOL
http://cnj.craigslist.org/ctd/2992913441.html
and last one be a little scepticle because i don't know if the corvette tranny will fit an olds? I don't know...
http://cnj.craigslist.org/pts/2913308969.html
Old May 4, 2012 | 08:41 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Doomah did your car originally have a TH350? If so get it rebuilt. Its often cheaper to simply have the orig trans rebuilt. No messing with guesing on tail shafts, bolt patterns etc...And the unknown factor of the used rebuilt craigslist unknown no warranty, way to risky IMO. You went through all the trouble of R&R-ing the trans only to find out its junk. Now you have to do it all over again. The cost is not much more than the prices your discussing here. Should be able to get a TH350 rebuilt with a converter for well under 1K, $6-800ISH. Then you can specify shift kit or any up grades you want and have a warranty to boot. Some trans shops stock rebuilt units on their shelves with a warranty. Jegs & Summit sell warranted units too. I purchased a street/strip/semi manual valved 400 with satruday night special converter shipped to my door for $1100.
Old May 4, 2012 | 09:16 AM
doc he has a powerglide... he wanted to update to a 3 or 4 speed auto..
Old May 4, 2012 | 11:02 AM
Doomah's Avatar
Yea I have a power glide right now. Yea more I think about it and read I should go with a TH350 and if I never chance the motor in a couple years I will just upgrade at that time. So now the search is on for a Th350 .
Old May 4, 2012 | 11:23 AM
I would do the same..... see above ( brian or J) to start your search....
Old May 4, 2012 | 11:34 AM
droptopron's Avatar
delete
If its bolted to an olds engine its a Jetaway.
Shipping might not be as bad as you think. I'd look into it from a board member.
If you plan on a transmission shop doing the swap they should be able to source a transmission for you. Think about what you will do for a shifter as well.
if you are paying to get the work done a Turbo 350 will come out to ALOT less money than a 400.
Old May 4, 2012 | 12:03 PM
Doomah's Avatar
I am column shift right now and i am going to go to a swap meets to get a center console and change it to a dual gate or at least that is what I want to do, O yea it is a jetaway almost the same thing as a powerglide.
Old May 4, 2012 | 05:10 PM
Actually, Jetaway transmissions were late 50's-early 60's transmissions.
64-68 2 speed transmissions were Super turbine 300s
People just kept calling them Jetaways, anyway.
68conv455
Drivetrain/Differentials
Apr 11, 2008 11:48 PM
Omicron
Jul 16, 2007 08:39 AM
mcutlass1969
Jan 3, 2007 10:29 PM
78Delta88
Sep 18, 2004 09:58 PM
cutlass72
Jan 2, 2004 05:26 PM
