power steering pump 66 cutlass
Guys thanks for your input I'm going back to the drawing board. Not ready for it yet might have to go to newer style the one down lower closer to block. My fuel rails may not clear the alternator with original setup. Thanks
Larry, I took the brackets off a 1970 98 455 and mocked up the front end. The pump from that setup needed the pulley shimmed out about 1/4 inch to line up. I wasn't sure if that pump was wrong for my 66 cutlass (67 425 in it) or there are different brackets because there is no way to move ps pump forward. Let me know what you think.
heres link to the spacers larry is talking about.
https://classicoldsmobile.com/forums...p-spacers.html
In a pinch when I could not find them in my stuff. I have used metal conduit for the front one and cut to length and several washers for the side one and used superglue to hold them together to make it easier to install them.
Hope this helps solve your issues.
Larry
Larry
cutlassmoe
August 4th, 2016 04:08 PM
nicks1966
January 12th, 2014 01:46 PM
MrPorkchops
January 21st, 2013 11:00 AM
