power steering pump 66 cutlass
Old Nov 6, 2017 | 06:18 PM
442iowa's Avatar
I'm in need of a power steering pump & pulley for 1966 cutlass with A/C
Old Nov 6, 2017 | 06:59 PM
toymobile's Avatar
I have a round canister pump, but no pulley??
Should fit a large flat rate box, $55.00 shipped,
Let me know, Thanks
Johnny
Old Nov 6, 2017 | 07:53 PM
lemoldsnut's Avatar
I can do the entire pump with brackets and pulley
Larry
lemoldsnut@aol.com
Old Nov 7, 2017 | 04:51 AM
oldspackrat's Avatar
I have a complete setup also if it gets to me.
Old Nov 7, 2017 | 12:15 PM
442iowa's Avatar
Guys thanks for your input I'm going back to the drawing board. Not ready for it yet might have to go to newer style the one down lower closer to block. My fuel rails may not clear the alternator with original setup. Thanks
Old Nov 7, 2017 | 01:04 PM
lemoldsnut's Avatar
I can probably help you with that as well.
Larry
lemoldsnut@aol.com
Old Nov 7, 2017 | 02:08 PM
442iowa's Avatar
Larry, I took the brackets off a 1970 98 455 and mocked up the front end. The pump from that setup needed the pulley shimmed out about 1/4 inch to line up. I wasn't sure if that pump was wrong for my 66 cutlass (67 425 in it) or there are different brackets because there is no way to move ps pump forward. Let me know what you think.
Old Nov 7, 2017 | 02:14 PM
lemoldsnut's Avatar
You probably forgot the spacer that goes on the block
Olds motors are all the same for those bolt spacings.
Old Nov 7, 2017 | 04:20 PM
RetroRanger's Avatar
72 Olds CS
heres link to the spacers larry is talking about.
https://classicoldsmobile.com/forums...p-spacers.html
Old Nov 8, 2017 | 09:01 AM
lemoldsnut's Avatar
In a pinch when I could not find them in my stuff. I have used metal conduit for the front one and cut to length and several washers for the side one and used superglue to hold them together to make it easier to install them.
Hope this helps solve your issues.
Larry
cutlassmoe
Aug 4, 2016 04:08 PM
nicks1966
Jan 12, 2014 01:46 PM
scott_442
May 21, 2013 04:24 AM
mike63078
Apr 23, 2013 12:00 PM
MrPorkchops
Jan 21, 2013 11:00 AM
