Power steering box return tubing
Old May 24, 2012 | 02:24 PM
at3reg98's Avatar
New 2 Olds
Had some rust by the box and the return tube that comes out of the box broke off. This is the screw-in, short angled metal tube that the rubber hose goes over and clamps onto. This is for an 80's era Olds but earlier may fit. If anyone has one please drop me a PM or email elcamino1970@hotmail.com. Thanks.
Old May 25, 2012 | 05:17 AM
ROCKETMAN269V's Avatar
I'll have to check for one; be advised that around '79-'80 the fitting going into the steering box changed from "inverted flare" to "O-ring" and from American to Metric on the hex portion.
Old May 25, 2012 | 01:50 PM
at3reg98's Avatar
New 2 Olds
The one I'm looking for is the o-ring style. Should be 16mm thread.
Old Jun 4, 2012 | 06:50 AM
Question Power steering box return tubing
Did you ever find the tube that you were looking for? Thanks, Bob.
Old Jun 4, 2012 | 08:22 AM
For the return line, you can just pick up a nipple that size at NAPA (angled or straight) and attach the hose with a hose clamp.
Old Jun 4, 2012 | 08:44 AM
^^^Agreed. The return line doesn't carry anywhere near the PSI that the pressure line does. You can prolly also get them at Autozone or O'Reilly's. Yup, just did an online search. They range from 6.50 to 13.50 at O'Reillys. They also have the pressure line for 17.99
Autozone has the pressure line - complete for less than 20 bucks. If you have rust issues with one hose, the other (pressure) prolly won't be far behind and it carries +1000 PSI
Old Jun 4, 2012 | 12:03 PM
at3reg98's Avatar
New 2 Olds
I ended up buying some rubber hose and a 45 degree fitting. There's a few different styles out there, none really specific to the car but as long as they had the 16mm end on them I could get them to work.
Olds Dad
Oct 1, 2014 07:54 AM
Octania
Sep 17, 2014 05:11 PM
74sprint
Suspension & Handling
Sep 11, 2014 11:37 PM
johns59super88
Jun 2, 2012 03:11 PM
68conv455
May 20, 2008 02:03 PM
