Please help!
Old Nov 1, 2020 | 05:42 PM
Joe Ferro's Avatar
Please help!
I’m in desperate need of rotors and hubs for a 1970 Oldsmobile 98 2 door c body convertible. Please tell me you have them or know where to get them? 🤞
Old Nov 1, 2020 | 06:01 PM
I moved your post to it's own thread. The thread you were in originally was about 68-72 Cutlass brakes, which are unrelated to yours. No one makes new rotors for the 67-70 full size cars. You CAN adapt the rotors from a 2003-06 Cadillac CTS with some minor machining. I've done this on my 67 Delta. See this thread for more info.
Old Nov 1, 2020 | 06:16 PM
Joe Ferro's Avatar
Omg thank you so much for the quick response! I will show that thread to the shop. How can I find hubs? I only have one usable one.
Old Nov 1, 2020 | 06:20 PM
You're kinda screwed on the hubs. They are unique to the disc brake cars. What's wrong with yours?
Old Nov 1, 2020 | 06:29 PM
Joe Ferro's Avatar
When the shop was separating the hub from the rotor he cracked the hub. So I only have one usable hub
Old Nov 1, 2020 | 06:34 PM
Joe Ferro's Avatar
This is the text message the shop sent me in regards to what we needed.
“1 hub cracked when he tried to separate the rotor from the hub,We have 1 usable hub and need two rotors and 1hub. We need to find the 11 3/4” chevelle rotor and it will work. Working on that. Jon has been reading every chance possible on it. Have you found anything?”
Do you think what they are suggesting will work?
Old Nov 1, 2020 | 06:41 PM
So that shop either needs to find you a new hub or have one machined from scratch at their expense. It may be possible to weld and remachine the cracked one. That won't be cheap. Chevelle rotors are 10.75" and are not even close to working for this application. I had no problem pressing the studs out of mine at home. I can't imagine how much they had to beat on that hub to crack it. You may want to find a shop that has a clue.
Old Nov 1, 2020 | 06:49 PM
Joe Ferro's Avatar
I don’t mind doing some of the leg work. And if there’s a possibility of fixing the one hub. I guess I’ll have to do it. When you say it won’t be cheap, what do you think ball park price would be?
Thank you for all your help and advice. Tomorrow I will be speaking with them and hopefully get this problem fixed and the car back soon!
Thank you again!
Old Nov 24, 2020 | 06:21 PM
65B01Delta's Avatar
contact jhoppeolds he's a member on here and he has some...
Old Nov 25, 2020 | 04:19 AM
rocketscientis's Avatar
Spare disc brake parts..
Delco moraine 5x5 pattern
Have an extra master cylinder also as well as an entire front disc brake B body setup..
Old Nov 26, 2020 | 08:24 AM
newmexguy's Avatar
The bearings / races interchange to anything else? Even something like '68-'82 Corvette? There was a flurry of late C3 stuff at one of the U Pull's a while back, but held off on buying anything, did not wish to be stuck with heavy un-sellable suspension parts. I may? still have the loose hubs pictured here, am not positive of origin, got them from a Guy who was trying to adapt them to a '65 Impala, he claimed they were corvette. Unsure. Does appear at one time they were "riveted" or "peened" to something, either a Rotor or a Drum. Also do not appear to be the common '64 - '74 A, F, and X body front Drum hubs.
68 D88
66
Aug 28, 2021 06:58 AM
1970 98
Nov 4, 2020 10:33 AM
68 D88
Aug 18, 2020 12:47 PM
sqeeek
Brakes/Hydraulic Systems
Jan 9, 2014 12:37 PM
darrenrf
Aug 16, 2009 01:22 AM
