Oil Pans Big Block vs. Small Black
Old Feb 21, 2015 | 04:08 PM
DEL663's Avatar
Some one was asking is there a differance between big block & small block oil pans? The oil pump is deeper on a big block. Big block oil pan is deeper then the small block oil pan. You can use a big block oil pan on a small black with the big block oil pump pick-up, but you can't use a small block oil pan on a big block.
Old Feb 21, 2015 | 06:21 PM
oldstata's Avatar
Justin
https://classicoldsmobile.com/forums/small-blocks/88567-oil-pans.html#post792781
Old Feb 22, 2015 | 08:57 AM
And if you checked that other thread, you'd have seen this photo, which clearly shows that the BBO pan (center) and SBO pan (rear) have exactly the same depth sump. The ONLY difference is the two "bumps" in front of the sump.
bocoogto
Aug 26, 2023 06:09 PM
landbarge
Jan 30, 2012 12:02 PM
antweave
Apr 22, 2011 11:32 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
