Need a Switch...73 Delta 88 conv top
Old December 2nd, 2007, 06:02 PM
1967 Delta 88?
arnyishere's Avatar
I am in need of a convertible top switch for a 1973 Delta 88.
arnyishere is offline
Old September 29th, 2009, 04:46 AM
dedsleds's Avatar
i am getting a 73 olds convert w/power top. email adedhed2@comcast.net
dedsleds is offline
Old September 29th, 2009, 05:28 AM
Lady72nRob71's Avatar
Even if you get a new switch, the old one may be repairable. The 72's are easy to repair, yours may be the same if physically intact. Usually the contacts inside get burned and need repolishing. And since it does not work anyway, why not try! Spares are nice to have.
Lady72nRob71 is offline
Old September 29th, 2009, 08:24 AM
Oldsdruid
rocketraider's Avatar
My luck repairing that switch was "not too good!" I think I got the last NOS one in GMPD system some time around 1995, or so the dealer said. After a couple years even it worked only marginally better than the original.
If cleaning/repairing doesn't work, go to any good electronic supply and get a SPDT (single pole, double throw, ON-OFF-ON) spring return toggle switch and its faceplate. I had one of them on my 73 for a couple years until I decided I HAD to have the OE switch, and it worked great. I found one with a paddle, cut its underdash bracket down to fit flush on the dash, and then used dry transfer lettering to duplicate the factory switch. Solder some 12 gage leads to the switch, then use bullet male connectors to connect the new switch to the harness. Odds are it will work as well as or better than the chintzy OE switch.
As is said, necessity is the mother of invention!
rocketraider is offline
Old October 9th, 2009, 10:19 AM
dedsleds's Avatar
i have one
dedsleds is offline
66olds98conv
Ninety-Eight
March 21st, 2013 12:52 PM
Delta88Vert
August 12th, 2012 11:39 AM
oldspackrat
January 30th, 2012 08:12 PM
The_German
August 28th, 2011 08:18 AM
StickW31
February 23rd, 2010 08:10 AM
Quick Reply: Need a Switch...73 Delta 88 conv top
