Need an Engine Wiring Harness for a1984 Hurst Olds
Old May 27, 2022 | 06:38 PM
James J's Avatar
I am in need of a 1984 Hurst Olds wiring harness. My car is a barn find and the mice have destroyed all of the wiring. Does anyone have one or know where I can get one Thanks James
Old May 28, 2022 | 04:35 AM
QS442's Avatar
I have a wiring harness. I can get pics on Mon
Old May 28, 2022 | 06:07 AM
Be aware that there are two "engine wiring harnesses", one for the traditional engine electrical functions that connects to the firewall connector under the brake booster and a completely separate ECU harness that operates the carb, distributor, and all the emissions functions that comes through a grommet under the HVAC box.
Old May 28, 2022 | 06:48 AM
69HO43's Avatar
Not to mention that there's a few minor wiring differences between a VIN 9 (Hurst/Olds) and VIN A or Y. But if mice has eaten yours, you probably need something from at least a V8.
Old May 28, 2022 | 06:53 AM
HighwayStar 442's Avatar
Would think any V8 wiring from 84 to 87 Cutlass or 442 would work. As a owner of a new 84 H/O at one time. Just curious to see what kind of shape she is in. Maybe some pictures?
Old May 28, 2022 | 06:54 AM
As noted, there are differences between VIN 9 and VIN Y harnesses, and differences from year-to-year. The basic harness is similar, but a few wires will require modification if a correct harness is not used.
Old May 28, 2022 | 07:05 AM
Was the 86 to 88 442 VIN 9 with stighly less HP. Finding a 84 VIN 9 will be hard to find.
Old May 28, 2022 | 06:56 PM
69HO43's Avatar
Originally Posted by James J
My 1984 Hurst Olds is a 307 V8
Yep. ALL 84 H/Os were 307. They were the only G-body Olds not hit with the late fall 1983 307 V8 restriction. Right about the time they were getting built, there was a foundry problem which put limitations on 307 production. They only allowed big cars and the H/O to skirt the restriction. I got a bulletin somewhere around here that talks about it.
The A/C circuit is slightly different for the VIN 9 vs. VIN Y. Additionally, the VIN 9 carb has an idle speed solenoid instead of a vacuum operated idle load compensator. They generally match up well, but there are some minor differences. That's what I can gather for the engine compartment right off the top of my head. Your best bet is to get a Chassis Service Manual, aka CSM (where have you heard that before?) that includes CUTLASS SUPREME on the cover (it does cover the H/O inside), and the accompanying electrical manual for your car. You should be able to troubleshoot and tune your 84 H/O with them. There are similar looking manuals for Ciera, etc., which you don't need. So get the right one. Electrical manual is for all series. There's also a thin electrical manual supplement if you think you would need it. I never found it of much use.
1984 Oldsmobile Cutlass Delta Custom Cruiser 98 Toronado Chassis Service Manual | eBay
Oldsmobile 1984 Electrical Troubleshooting All Series Original Sevice Manual 84 | eBay
1984 Oldsmobile Electrical Troubleshooting Service Manual Supplement All Series | eBay
Old May 28, 2022 | 07:31 PM
They all are. Your H/O uses a VIN 9 307, which was unique to the 84 H/O. All other Olds 307s that year were VIN Y with less HP and some small changes to the wiring harness (like the use of a vacuum idle control on the VIN Y vs a solenoid on the VIN 9).
Old May 29, 2022 | 11:36 AM
newmexguy's Avatar
You might? find someone parting one, or with a stash on www.gbodyforum.com. I haven't had much luck selling there, but there does seem to be a fair amount of people there with parts. No G bodies left here in the yards, the pick a part model has seen to that. Speaking of pick a parts, the www.row52.com site could be used to locate a Donor, but good luck getting anyone to respond to your wanted ad. But, maybe, it could be used to locate a suitable Donor within a day's drive.
Old May 29, 2022 | 06:18 PM
James J's Avatar
I have the body harness I just need the carburetor & distributer, computer command control. As Joe said the VIN 9 uses a throttle kicker solenoid. I have tried M&H, Americanauto wire, Painless, some Oldsmobile only junk yards everybody has things through the 1970's. The only way to get one is from a junk car. I already have the Service Manuals. I am very good with wiring & electronics, I fix old stereos for a hobby. There is not much of the original wiring left, not enough to repair. Bonus, took off the Q Jet to rebuild it today & the body rusted so much a piece by the secondary is missing, probably because of the mice mess. So now I have to get a different carburetor. Thanks ... P.S. my car has AC & Cruse control
Old May 30, 2022 | 06:34 AM
newmexguy's Avatar
Uric acid / ammonia in Rodent **** is very corrosive. I've seen recently an individual here who found two NOS carb bodies out there so they exist. Quite a few Carb specialists out there, also, they should have parts. Have to wonder, if you have your original harness connectors, M & H can't build a "from scratch" harness, providing you sent them the remains of your harness, and perhaps a reprint of the original engine harness diagram?? Could have sworn I viewed their catalog a while ago, and they did have a small bit of early eighties stuff available.
Old May 30, 2022 | 06:44 AM
69HO43's Avatar
Pic of carburetor? Depending on the issue, I may can help.
BTW, ALL 80s Olds G-body VIN 9 cars were required to have A/C option installed. Just how it was.
Old May 30, 2022 | 08:13 AM
ROCKETMAN269V's Avatar
........ took off the Q Jet to rebuild it today & the body rusted so much a piece by the secondary is missing, probably because of the mice mess. So now I have to get a different carburetor........l
I believe that I still have an '84 H/O carb core, as well as a complete wire harness. We recently moved, so still sorting out boxes of parts. If interested, email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old May 30, 2022 | 06:09 PM
James J's Avatar
newexguy, I called them and they only had Chevy g bodys up 'till '82. No Olds, and no after 82. No digital pictures right now, father has the digital camera on his vacation. Butterflies have rusted to the bores, and the rust dripped down into the intake. Thankfully it's aluminum and can be cleaned. Rocketman/Bob: That would be amazing if you have the exact parts ! email on it's way. My nephew is coming to visit on the 17th. He is 15 and car crazy with a 1990 V8 Lexus of his own and wants to learn how to wrench on stuff. Trying to gather these rare parts I didn't even know I needed before then so we can return this Hurst to the road.
Old Jun 2, 2022 | 04:52 PM
oldolds88's Avatar
vin 9
i have a vin 9 that is ventilated on the side,but have the heads, intake, rebulidable carb,ect.
Old Jun 13, 2022 | 06:22 AM
.......... Rocketman/Bob: That would be amazing if you have the exact parts ! email on it's way.........
Wire harnesses all boxed and ready to ship. I will be dropping them off this morning. Thanks, Bob.
James J
May 21, 2022 04:51 AM
fjwhoopie
Jul 28, 2021 06:06 AM
Hoffa65
Mar 13, 2019 12:08 PM
XTREMEGSXR
Jun 5, 2012 10:29 AM
mycut
Aug 25, 2010 07:49 AM
