Where can I get an engine wiring harness for my 84 HO
Old May 12, 2022 | 06:44 PM
James J's Avatar
Mice have eaten the wires on my Barn Find Hurst down to the connectors in some places & can't be repaired. Need a new engine harness & AC if that is separate. So I can try & start this car up for the first time & get it running. I've looked at some catalogs & they only had Chevy V8 & Buick V6 harnesses. Thanks
Old May 12, 2022 | 08:57 PM
edzolz's Avatar
Try to search for a company called wiringharness.com Just as I have written it, no space.
Old May 16, 2022 | 03:29 PM
James J's Avatar
Does this substitute Wiring Harness have TPS
I have tried all of the suppliers, no one makes a new harness. Mondellos says they have one for $175. Our local u pull it yard has an 86 5.0 Buick Regal that is likely the same one, though I do not know for sure because I haven't looked at this one very closely, not sure if it has TPS. Thanks
Old May 17, 2022 | 05:49 AM
James, you're going to need the same skills whether you replace the engine wiring harness or repair the damaged wires and connectors. If you aren't confident in your skills I suggest you get a buddy to help that's familiar with splicing and soldering. Of course, you could always replace the entire harness with a Painless kit, but that's no easy task:
https://www.painlessperformance.com/...SAAEgJjxfD_BwE
Old May 20, 2022 | 08:01 PM
MO Olds 2022's Avatar
Maybe get a service manual with a wiring diagram and do a side by side for comparison for the Regal. Might be close? Otherwise $175 isn't too bad considering your time involved. I did mine from scratch for a 79 trans am but buying new was only $220 and would have saved many trips to the parts store.
if you end up starting from scratch, I can't recommend Texas Industrial enough at the link below. They have every GM connector.
http://texasindustrialelectric.com/
Old May 21, 2022 | 04:51 AM
brianbeez67's Avatar
Did you try American Auto Wire out of NJ, they do a great job
fjwhoopie
Jul 28, 2021 06:06 AM
Hoffa65
Mar 13, 2019 12:08 PM
jo75olds
Jun 14, 2011 08:34 PM
mycut
Aug 25, 2010 07:49 AM
Maverick
Jul 30, 2008 07:51 PM
