Looking For a Working POA Valve For 70 442
Old Jul 8, 2022 | 06:23 AM
sanded1's Avatar
My POA Valve for my 70 442 is stuck wide open so the system does not cool properly (barely) I have tried one of the POA replacement tubes that change the system to a cycling clutch style but with the old "A6" compressor it really screws up drive-ability (surges) every time the clutch cycles . I have seen some "You Tube" videos of them being rebuilt or the other options are finding a verified working used one or rebuilding mine which looks simple enough other than I don't own a "TIG" welder and I don't know if soldering it back together will work. As always any input is appreciated.
Old Jul 8, 2022 | 06:30 AM
70sgeek's Avatar
'72 Cutlass ragtop
Check Classic Auto Air https://www.classicautoair.com/
they may have what you need or can rebuild yours
Old Jul 8, 2022 | 06:40 AM
sanded1's Avatar
Thanks, I have. Roughly $300 to rebuild and I may end up going that route, just looking at options since I feel like I wasted money on the POA eliminator piece.
Old Jul 8, 2022 | 07:59 AM
dc2x4drvr's Avatar
They tig weld the POA valve body sections together after rebuild. I just removed my working POA valve, I’m replacing it with a billet POA valve, it converts ac system to cycling, but I’ve ran the Pro6Ten compressor for years, so no issues with cycling.
Old Jul 8, 2022 | 08:17 AM
70Post's Avatar
I have an original POA valve from a '70 442 that was converted (for use w/134A)/rebuilt by Classic Auto Air in 2018. It was installed on the car and the system was charged, etc but there were other problems w/the system so the valve was immediately removed, put in a box and stored inside a house.
The finish on it isn't perfect....I think they take them apart and plate them w/zinc plating and it has some imperfections in the finish. It's NOT pitted, etc.
Maybe you could send this over to Classic Auto Air for testing/inspection or see what they say about checking it out to make sure everything's fine w/it.
I have the original receipt from them for the work. The cost back then was 246.99 (rebuild/conversion + R134A adapter). Let me know if you're converting to R134A or not.
I'll send you a PM w/price. A couple pics below.
Old Jul 9, 2022 | 12:30 PM
Bee Saint Louis's Avatar
CutOvers Olds Parts Guys
rcorrigan5
Mar 22, 2026 02:09 PM
chip-powell
May 4, 2016 02:34 PM
Nop
Mar 7, 2014 05:48 AM
Porter858
Mar 21, 2013 10:47 PM
Al Graaf
Apr 6, 2012 08:46 PM
