Looking for A-pillar piece
Old Aug 21, 2010 | 01:29 PM
bammax's Avatar
I need the drivers side A-pillar outer skin from a 1980-1990 b/c body car. I don't need the entire pillar, just the outer layer which wraps around and holds the window channel. Mine is rotten and I'd save a ton of money if I can graft in a new piece instead of having one made from scratch.
I know it'll be a hard find but you never know if you don't ask. I figure someone must have a Custom Cruiser or Delta 88 that they're planning on junking for whatever reason.
I know of a couple in junkyards near by, but they don't like the idea of cutting out the pillar since the windshield needs to be removed and there's a risk of breaking it.
Any help or leads to someone who could help would be appreciated.
Old Aug 21, 2010 | 03:20 PM
OLDSRALLYE350's Avatar
Where are you located ? And maybe a picture of where it would need to be cut to get you the correct amount of repair area
Old Aug 21, 2010 | 04:33 PM
bammax's Avatar
I'm up in Massachusetts.
When you pull the inner trim you can see where the metal wraps around the pillar and is welded down. I'm looking to drill out the spot welds from top to bottom and get the entire thing if possible. In reality I need to get it from just below the halfway point all the way up to the roof and possibly about 6" of the roof panel itself, but that's not necesary.
Here's the reason I need it
Gotta love vinyl roofs huh
Old Aug 22, 2010 | 03:14 AM
pudro's Avatar
sanblast and j b weld it-if u do it right it will out last u!!!!!
Blake Willoughby
Aug 29, 2013 05:24 AM
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
Bluevista
Apr 22, 2008 05:33 AM
Pinner
Apr 1, 2007 11:48 AM
perrygil
Mar 15, 2007 08:43 AM
