Lookinf for a 70 455 block code 30Mxxxxxx
Looking for a 1970 olds 455 block with the date code 30Mxxxxx on it. Just need the block but will take the engine as well
314-495-1700
Chris
I'm in St.Louis but will go as far as 600 miles to get it.
314-495-1700
Chris
The 30M is how they stamp the VIN on the block
3 = Oldsmobile
0 = 1970
M = Lansing(or whatever plant your car was built)
XXXXXX = the last 6 digits of the VIN on the car.
The transmission is stamped the exact same way.
There is a julian date on the back of the block,directly next to the distributor hole,which indicates the date of the year it was made. 295 = 295th day.
3 = Oldsmobile
0 = 1970
way down here in texas... more then " 600 miles " ... but i have both a 72 julian dated block and a 1970 . The 72 block is cleaned with a std bore and the block from the 70 442 is not so good; needs a sleeve and most likely punched .30 over. If 70 is what you are after I can get you the actual day stamped near the dist.
Tfitz
February 9th, 2016 03:39 PM
ut442
March 9th, 2012 11:57 AM
