Lookinf for a 70 455 block code 30Mxxxxxx
Old Jul 5, 2013 | 08:20 AM
cdoering's Avatar
Looking for a 1970 olds 455 block with the date code 30Mxxxxx on it. Just need the block but will take the engine as well
314-495-1700
Chris
I'm in St.Louis but will go as far as 600 miles to get it.
Old Jul 5, 2013 | 10:57 AM
507OLDS's Avatar
That's not a date,that's the VIN.
When was your car built?
Old Jul 5, 2013 | 11:40 AM
cdoering's Avatar
The engine block will have 30M followed by 6 digits. I have a 70 olds 442. I know its not the vin. My vin is 344670Mxxxxxx.
Old Jul 5, 2013 | 01:07 PM
classicmuscle442's Avatar
507olds is correct, the 30m is the start for the vin
Old Jul 5, 2013 | 01:46 PM
507OLDS's Avatar
The 30M is how they stamp the VIN on the block
3 = Oldsmobile
0 = 1970
M = Lansing(or whatever plant your car was built)
XXXXXX = the last 6 digits of the VIN on the car.
The transmission is stamped the exact same way.
There is a julian date on the back of the block,directly next to the distributor hole,which indicates the date of the year it was made. 295 = 295th day.
Old Jul 6, 2013 | 09:31 PM
lunaboy's Avatar
The Rocket Astronomer
way down here in texas... more then " 600 miles " ... but i have both a 72 julian dated block and a 1970 . The 72 block is cleaned with a std bore and the block from the 70 442 is not so good; needs a sleeve and most likely punched .30 over. If 70 is what you are after I can get you the actual day stamped near the dist.
Old Jul 7, 2013 | 04:41 AM
tru-blue 442's Avatar
Old School Olds
I also have a 455 with a pad stamp
that begins with 30M, complete with E heads
from a 70 Cutlass. It would need a rebuild as well.
Old Jul 8, 2013 | 10:43 PM
Nickyloves442s's Avatar
I have a replacement block with no vin stamping on it. Im in colorado. 720-275-3124
Tfitz
Feb 9, 2016 03:39 PM
TicTocTach
Jun 16, 2015 04:03 PM
Boldsmobile
Nov 2, 2011 06:02 PM
rrielley
Feb 9, 2008 10:43 AM
