hubcap tool
Old Jan 25, 2010 | 05:49 PM
onecutlass's Avatar
R.I.P S.K.P
hubcap tool
does anyone have the tool to help me unlock these hubcap off my 83?
if you have a pic of it i can wait and get it fron good ole gm tia !
heres the granny spoke wheel
Old Jan 26, 2010 | 02:45 AM
Yellowstatue's Avatar
Smile Trapped
That little rocket just pops off and then what you need is a tubular key with the correct CODE letter...stamped on the end of the lock bolt is a letter A, B, C, etc. and then when you have the letter off the bolt go to the wreckers and see if they have yours in stock...they usually do not throw those things away... the dealer price might be a little high
Old Jan 26, 2010 | 04:59 AM
It might be a little high if you are Bill Gates or Warren Buffet. If you are a normal guy then you probably can't afford the dealer price.
Old Jan 26, 2010 | 05:59 AM
Lady72nRob71's Avatar
Post the letter here when you get it.
My mom stupidly got rid of her 86 Olds after failing emissions and it had a MINT set of these hub caps. It went to the boneyard somewhere but she kept the hub cap key. I will try to remember to ask her if she still has it and find out the letter.
Old Jan 26, 2010 | 06:06 AM
Bluevista's Avatar
Registered
One word will get those wheel covers off...BFH.
Old Jan 26, 2010 | 06:17 AM
csstrux's Avatar
Usually a good tire shop will have tools to get them off as well. They will be universal and might mar the bolt up...but they will be off.
Old Jan 26, 2010 | 08:49 AM
onecutlass's Avatar
R.I.P S.K.P
hey there fellas if i can find the tool is there another way to get the lock off on another olds board i was told i can get them off with needle nose pliers iam plan on keepin the hubcaps if i plan on selling the car ! thanks in advance !
Old Jan 26, 2010 | 08:59 AM
onecutlass's Avatar
R.I.P S.K.P
i cant see any letter any bolt on all four corners ! how does the tool work does it push or pull the halfmoons ?
Old Jan 26, 2010 | 09:37 AM
marcar1993's Avatar
It has half moons that catch the half moons on the bolt to turn it, like a normal socket would on a normal bolt.
Yes, you can use needle nose pliers, that is what I did. Then I just used a normal bolt (1/4-20 I think) with a washer under the head so now I can remove them with a socket and a ratchet.
Old Jan 27, 2010 | 02:31 PM
onecutlass's Avatar
R.I.P S.K.P
i got them off took two screwdrivers to get them off ! thanks too all that chimed in !
thank so much fellas !
deaddds
May 13, 2010 06:04 AM
vettemad
Jan 20, 2010 10:23 PM
27T
Dec 10, 2008 12:44 AM
Rabbit
Feb 12, 2007 10:53 PM
