Here's an odd ball one!
I know I don't need to have this to have the car run right. I know that the stupid things doesn't do anything. so that being said. I have a 72 350 with AC. I need the anti diesel/ idle solenoid bracket that mounts to the front of the 4bbl Rochester carb and the two screws that hold it on. I am trying to restore her back to 100% stock / correct. I also need the small clip with two holes in it that mounts to the top center valve cover bolt to hold the alternator wiring. last thing is the jumper wire from the main harness to the oil pressure switch.
clips
Or are you talking about this clip that is part of the ignition wire looms that uses the top center valve cover bolt on the passenger side and holds the modulator line on cars without OAI?
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/800x209/dsc08779_78f21b195c5ce2a5be8a390d6bf9343027a54092.jpg)
Actually, Classic Industries even sells them as a kit for the 403-powered T/As in their Firebird catalog.
![](https://cimg1.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/800x608/ta4033_9ea96a28fa6d64cc27f5e10efac6cbc6230ed3af.jpg)
costpenn
September 20th, 2020 02:52 PM
