Here's an odd ball one!
Old Mar 20, 2016 | 12:38 PM
bigin1978's Avatar
North Coast Rockets
I know I don't need to have this to have the car run right. I know that the stupid things doesn't do anything. so that being said. I have a 72 350 with AC. I need the anti diesel/ idle solenoid bracket that mounts to the front of the 4bbl Rochester carb and the two screws that hold it on. I am trying to restore her back to 100% stock / correct. I also need the small clip with two holes in it that mounts to the top center valve cover bolt to hold the alternator wiring. last thing is the jumper wire from the main harness to the oil pressure switch.
Old Mar 20, 2016 | 03:25 PM
With or without the clips for the modulator pipe? Supercars sells both.
Old Mar 20, 2016 | 06:08 PM
bigin1978's Avatar
North Coast Rockets
I didn't know there was a difference from side to side.
Old Mar 24, 2016 | 05:47 PM
bigin1978's Avatar
North Coast Rockets
bump
Old Mar 25, 2016 | 07:42 AM
airvegas's Avatar
clips
Or are you talking about this clip that is part of the ignition wire looms that uses the top center valve cover bolt on the passenger side and holds the modulator line on cars without OAI?
Old Mar 25, 2016 | 08:46 AM
From the original post in this thread:
Even without O.A.I., the two hole clip was used to hold the wiring. This wire retainer fit into the upper hole:
Actually, Classic Industries even sells them as a kit for the 403-powered T/As in their Firebird catalog.
costpenn
Sep 20, 2020 02:52 PM
gus91326
Oct 28, 2015 08:55 PM
Jamesbo
Hurst/Olds
24
Dec 14, 2010 09:21 AM
OldsMotion
Nov 16, 2006 04:45 AM
