Help??????
Help??????
I'm trying to Finish an 18mo Project restoring my Grandmothers Cutlass
76 Olds 4dr Cutlass Supreme
Items Needed
Left Exterior Door Handle-- approx. 6 1/4" in length Chrome
1. I know you can get aftermarket however they are only 5 3/4" and back spacing is wrong
Right Rear Wheel Well Trim
also looking for Right Exhaust manifold for 350 Olds with out Cross Over Pipe
need 5 wheel bezels
any help is greatly Appreciated you can email me @ 76carcrazy@gmail.com
Paul
And on The great se
Items Needed
need 5 wheel bezels
Paul
And on The great se
To clarify slightly, all 1964-1990 RWD small block Olds manifolds have the second port for the crossover. Toro manifolds from the 403 cars do not, but the outlet isn't turned correctly for a RWD application. Of course, BBO manifolds are available for true dual exhaust applications, but they have clearance issues on the shorter deck SBO.
Heres a link to their online Olds catalogue. Page 62/63 http://online.flipbuilder.com/wmmk/nfjp/#p=64
Thornton does have a set of 350 exhaust manifolds that mimic the big block Olds but it's way more expensive than buying and installing a block off plate.
You can buy just the passenger side small block manifold with the single outlet....I almost bout one on eBay and stumbled onto a 455 and went that way..I did buy a set of thorn tons 455 manifolds...pretty nice..haven't used them yet but look very good
26.00 from Inline Tube Part number 11605
[QUOTE=76cutlass;922943]I'm trying to Finish an 18mo Project restoring my Grandmothers Cutlass
Items Needed
1. I know you can get aftermarket however they are only 5 3/4" and back spacing is wrong.
Hey Paul,
Do you know if the aftermarket door handles are the same for the 2door as your 4 door cutlass supreme?
This may help other members when looking to purchase those door handles
Eric
Items Needed
Hey Paul,
Eric
I went with the Thornton's on my 77 for a couple reasons: 1- all the bolts sheared off when I was taking the exhaust apart (I could of drilled and tapped them out but didn't want to) and 2- I wanted both outlets to be the same size. That made connection to the down pipes a lot easier in the end.
I get that Thornton Jr's are 2 1/4" instead of OEM 2", but I'd like to know how you figure that the outlet on the OEM 350's are different sizes. They are the same. The connection to the downpipes should be constant so I again don't see how that's an issue either. Thornton manifold length is the same as OEM, only difference is the slightly better flow pattern inside. Of course working with new parts is always a bit easier.
ToronadoGuyDenver
Brakes/Hydraulic Systems
March 18th, 2007 03:52 AM
