headers
Old Nov 23, 2009 | 12:53 PM
olds67's Avatar
headers
I need a headers for '67 Oldsmobile Delmont 88 425
thanks
Old Nov 23, 2009 | 01:15 PM
thanks
Good luck with that. The 65-70 full size cars are unpopular and thus there is little market for the header manufacturers to spend money on development.
Old Nov 23, 2009 | 02:20 PM
You can make them using one of the DIY header kits if you have decent fabrication skills.
Old Nov 24, 2009 | 09:48 AM
olds67's Avatar
Now I understand why I can not find anything
Old Nov 24, 2009 | 09:50 AM
olds67's Avatar
if we want to change, are a person who never pulls back.
Die Linke is where I can find these kits?
thanks
Marcello
Old Nov 24, 2009 | 10:31 AM
You should be able to find DIY header kits for an Oldsmobile engine from suppliers like Summit.
Old Nov 24, 2009 | 10:45 AM
Oldsmaniac's Avatar
Why Headers and not just factory style dual exhaust. I assume you have a BB engine?
Old Nov 24, 2009 | 10:57 AM
olds67's Avatar
My Olds mounts originally a single exaust, I would have two.
I do not know if BB.
is a 425 low compression heads C
Old Nov 24, 2009 | 11:16 AM
Oldsmaniac's Avatar
A 425 is a BB. The Left side factory style dual exhaust S manifold is reproduced and available from Thornton. The right side manifold is the same for all 67 BB engines in the B body. The crossover pipe is capped and you have a factory style dual exhaust. The auto shift linkage may need modification if using stock pipes on the drivers side. A muffler shop can bend pipes to clear the linkage on this side. Headers are not my first choice for a street car/daily driver.
Old Nov 24, 2009 | 11:28 AM
olds67's Avatar
BB is BIG BLOCK ok
Now I try to find the name I gave to the Internet.
I know it is for use quadruples but here we use it solely for these cars rallies
thanks
marcello
Old Nov 24, 2009 | 11:37 AM
Oldsmaniac's Avatar
http://thorntonmusclecars.com/products/manifolds
Old Nov 24, 2009 | 11:39 AM
D Appeldorn's Avatar
than my question,
my 69' olds 88 have molded sections in the chassis for dual exhaust.
it's a 350 4bll, autoshift.
what is the easiest and better to get dual exhaust with balancepipe.
2 seperate headers with seperate exhaust ore cut the exhaust after they come together and split them again.
and what size's of diam. is recommended, if the olds is reasembled again i'm going to make a exhaust of rvs steel.
Old Nov 24, 2009 | 11:51 AM
olds67's Avatar
Delta 88 is not the same as body?
Old Nov 24, 2009 | 02:10 PM
The Delta 88 and Delmont 88 are both B bodies. Oldsmaniac has a good point, standard dual exhaust manifolds are a good choice for a street driven car. I've only heard good things about Thornton. Plus, you don't have to worry about manuafacturing anything.
Old Nov 24, 2009 | 02:25 PM
Oldsmaniac's Avatar
For a street cruiser with the smallblock 350 you can run dual exhaust. One pipe on each side with no joining. You can use 2inch or 2.25 inch pipe. If you want to add a crossover/balance pipe it would be your choice but not necessary in my opinion. On a 350 engine you do not need the S manifold that the 425 would require.
Old Nov 25, 2009 | 04:24 AM
olds67's Avatar
Many thanks for your information.
I had read about for body manual body that were the same but a confirmation given by you and much better.
THANKS!!!!!!
Old Nov 28, 2009 | 01:52 PM
olds67's Avatar
found those of a Delta 425, I found them and I have used them, if they are not good hack.
thanks
Wyze
Mar 18, 2012 01:59 PM
martine
Feb 13, 2007 11:57 AM
JoshF85
Jan 24, 2006 10:20 AM
javi58
Apr 20, 2005 07:53 AM
<72>
Nov 11, 2004 09:09 PM
