Good OE Used Inner Tie Rod & Rear End Braces 70 442
Looking for a good original Saginaw inner tie rod end. Boot condition unimportant, but must be a Saginaw with the S on the bottom face of the end, joint still firm, and the weird zerk sticking out the side of the joint. Also need a good set of the rear end to frame stiffeners - light pitting is OK, but I will need to see pics.
I have many leftover parts but not all are 1970 and very few are 442 and NONE are 1970 442.
Chris, I believe they are all the same , but it has to be for a 68-70 A body Olds. The 71-72's are different. If you would have a good OE center link I'll take that too - mine had a bad drag link to Pittman arm joint. Thanks again - vacuum advance came out pretty nice!
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
I have several oem steering linkage set-ups, complete. I can provide whatever you need in the way of individual parts. As far as the braces go, I have (1) NOS and no used that I can think of. E-mail me direct: drolds1@bellsouth.net. Thanks, Bob.
Joe
Alex72cutty
July 14th, 2012 06:37 AM
