GM HEI Distributor
Old Jan 28, 2024 | 05:52 PM
Chuck Cole's Avatar
Oldscarnut
Question GM HEI Distributor
Old Jan 29, 2024 | 04:48 AM
Good luck in your search. 👍
Old Jan 29, 2024 | 12:41 PM
Chuck Cole's Avatar
Oldscarnut
Old Jan 29, 2024 | 03:16 PM
There’s one for sale in this posting:
https://classicoldsmobile.com/forums...butors-150187/
Old Jan 30, 2024 | 07:54 AM
ROCKETMAN269V's Avatar
That appears to be the later model, computer controlled, distributor. I believe that op is looking for a 3-wire with vacuum advance.
Old Jan 30, 2024 | 11:55 AM
I couldn't tell much form the pictures, but his description says he has a 1978 HEI available, which should be for a non-computer engine.
Originally Posted by newmexguy
Miscellaneous Oldsmobile Distributors.
#1111286 8 C 20 (March 20th, 1968) $50
#1112936 4 K 8 (Nov 8th, 1978) HEI $60
#1112195 4 A 4 (Jan 4th, 1974) $45
#1112198 2 G 3 (July 3rd, 1972) $50
#1112990 7 C 8 (March 8th, 1987) HEI, non Vac Advance?
Units left are:
1112195 (4 A 4)
1112198 (2 C 3)
1112286 (8 C 20)
1112936 (4 K 8) HEI
Old Jan 30, 2024 | 08:46 PM
joes_olds's Avatar
You pretty much can get a remanufactured GM unit at any auto parts store. Doesn't sound like you're looking for a specific distributor #.
I put one for a 76 350 in my 69 350. The GM unit has an internal coil, not sure what your MSD unit has. It's fairly simple to find detailed instructions to convert the points to HEI if needed. An unskilled person like myself took about 5 hours to get it to my liking.
Old Jan 30, 2024 | 09:01 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If you go with a conversion of your points distributor, do not use Pertronix. I used two different ones in the 54 I had and they both left me on the side of the road. The GM HEI is really not going to give you any more power but is a lot less maintenance. I had one in a 72 Cutlass 350 for over 20 years with no problems.
Old Jan 31, 2024 | 06:00 AM
VC455's Avatar
Barely Registered
As Glenn says, HEIs are usually bullet-proof. I, too, used one for about 20 years without a problem.
Just for your information (not trying to convince you to go through a third try), MSDs should also last a very long time. I've installed and worked on many, and I've seen two failures. The two that failed didn't have the MSD PN 8830 capacitor on the power wires.
The failure mode is from voltage surges and spikes resulting from hot connect/disconnect of poorly-regulated chargers, and from jump starts. The capacitor protects the MSD from those problem situations.
This is how it's wired
Old Jan 31, 2024 | 08:41 AM
newmexguy's Avatar
Clarification
I sent Mr. Cole a message. I have two or three distributors that are HEI, that are Olds, and have Vacuum advance. One of them is this near new "Spectra" one currently advertised. Pulled it, and the Carb off a '76 Cutlass with an Olds 350 engine. Appears it was installed, and then car was discarded. It is in it's own ad, and not with the other remaining distributors. Still have the late Seventies Original HEI unit as well. .
bigdan1
May 11, 2024 08:57 PM
W-27
Feb 25, 2020 09:29 AM
redoldsman
Aug 9, 2014 09:51 AM
70sx455
Jun 25, 2014 10:42 AM
68ragtop
Mar 28, 2009 10:08 PM
