Fuel pump plate
DOH! I never even thought of that!
Not that those cars are particularly common in wrecking yards anymore, but I actually took the rear disc brakes off of one a couple of years ago in a local yard and didn't even consider the fact that there was a blockoff plate!
As far as making one, I've started with one for a Ford. The Ford plate is longer than needed for an Olds, so I just drilled a new lower bolt hole. I didn't even bother to trim the plate to length, but you can do that if you want.
j_link
June 14th, 2012 10:04 PM
