Fuel pump plate
Old Jul 18, 2014 | 09:26 AM
sammieolds's Avatar
Fuel pump plate
Hi all does any one have a fuel pump block off plate?
Thanks Steve
Old Jul 18, 2014 | 09:51 AM
Steve you can fabricate one out of steel or stainless, use a gasket as a guide.
Old Jul 18, 2014 | 01:31 PM
sammieolds's Avatar
Good idea
Steve
Old Jul 18, 2014 | 06:59 PM
Run to Rund's Avatar
Late 70s Caddy Sevilles used one!
Old Jul 19, 2014 | 07:35 AM
DOH! I never even thought of that!
Not that those cars are particularly common in wrecking yards anymore, but I actually took the rear disc brakes off of one a couple of years ago in a local yard and didn't even consider the fact that there was a blockoff plate!
As far as making one, I've started with one for a Ford. The Ford plate is longer than needed for an Olds, so I just drilled a new lower bolt hole. I didn't even bother to trim the plate to length, but you can do that if you want.
Old Jul 19, 2014 | 02:42 PM
ferndaleflyer's Avatar
Frank Trimble in Laural, MD makes and sells those if you look him up on here or google.
sammieolds
Jul 18, 2014 09:38 AM
vette442
Nov 17, 2013 05:14 PM
BenJammin
Oct 9, 2013 09:41 AM
sshriber
Mar 22, 2010 06:16 PM
