Driveshaft needed.
Old Dec 4, 2008 | 03:27 AM
ziff396's Avatar
Driveshaft needed.
Hello:
I need a driveshaft and yolk for a 72 Cutlass (or 71) with a Turbo 400 and a Corp. 10 bolt rear.
Thanks Kevin
Old Dec 4, 2008 | 09:47 AM
rocwal
Guest
Posts: n/a
driveshaft wanted
I PM'd you about the drive shaft out of my 72 cutlass ,need length of it ,mine is 61 inchs from outer edge of front universial joint to outer edge of rear and has the yoke with joints in place
rocwal
Dan B
Old Dec 4, 2008 | 05:21 PM
ziff396's Avatar
Thanks, but my original from the turbo 350 measures 55.25 from center of u-joint to center of u-joint with a 5 " 27 spline yolk. I need a 32 spline yolk for the turbo 400. The turbo 400 is 3/4" longer than the 350. I noticed in my assembly manual that there are about 5 different driveshafts for the Cutlass depending on trans and rear, however they do not give specs.
Kevin
Old Dec 4, 2008 | 06:17 PM
71 delta88guy's Avatar
I would expect the different lengths are due to the th350,th375 and the th400 being used. That with the rear end choice and a lot of shafts are possible. I had to make my own driveshaft for my 74 delta 88. Had a th375 with an open 12 bolt. Got a th400 with a posi. Same rear different yoke's . Had to cut the th400 yoke to give allow for driveshaft/rear end movement.Good luck.
Old Dec 5, 2008 | 10:38 AM
rocwal
Guest
Posts: n/a
driveshaft wanted
Hi Kevin .
I have a 69 Delta with a 350 motor and a Th400 trans , diffy is the small one I'll check it for length .
rocwal
Old Dec 5, 2008 | 12:49 PM
rocwal
Guest
Posts: n/a
driveshaft wanted
Sorry Kevin. The delta is about 61 3/4 long from end to end .
rocwal
Dan B
Old Dec 8, 2008 | 06:19 AM
ROCKETMAN269V's Avatar
Smile DRIVESHAFT/YOKE
I have one out of a '72 Cutlass convertible that had a T-400 in it. We swapped in a 700-r4 for the overdrive. The T-400 shaft has about 1,000 miles on it since it came from the driveline shop, balanced with new u-joints. It measures 54 3/8" center to center on the u-joints.
65oldsguy
Aug 26, 2012 10:30 AM
Flye
Mar 2, 2011 08:20 AM
esisson
Apr 1, 2009 08:30 AM
J-(Chicago)
Drivetrain/Differentials
Sep 24, 2008 06:53 AM
ChrisM
Aug 12, 2008 02:22 PM
