Driveshaft
Old Feb 26, 2017 | 08:10 AM
68442's Avatar
Driveshaft
Need a "1 piece" drive shaft/yoke from a 1970 Cutlass 350/TH350.
I think 69-70 would be the same.
The critical Number Is 56" Center to Center of U joints.
Old Feb 26, 2017 | 08:32 AM
sammy's Avatar
Sammy70 455 Supreme
Where are u located?
Old Feb 26, 2017 | 08:44 AM
68442's Avatar
Massachusetts
Old Feb 26, 2017 | 08:54 AM
ROCKETMAN269V's Avatar
Driveshaft
I ship driveshafts all over the country. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Feb 26, 2017 | 10:34 AM
RetroRanger's Avatar
72 Olds CS
I might have one in mass I'll chk and post back later today.
Old Feb 26, 2017 | 11:23 AM
72 Olds CS
heres what i have not sure on exact application (tell me if you know) measures ~55..25" ctr to ctr on ujoints... ~56.5" end to end PM me w interest.
Old Feb 26, 2017 | 12:20 PM
72455442RA's Avatar
looks like retro
may have you covered
here is mine for consideration after the others
just went out and snapped a few and retro had posted ...
should clean up nice ... hit one spot with wire brush and cleaned up easily
yoke is really nice no rust or groove at the seal ...
original u joints,,,, feel fine ... bolt in and drive or replace
Scott
Old Feb 26, 2017 | 04:23 PM
68442's Avatar
Thanks Guys
Retro that one is going to be to short.
72455 I sent a responce to your PM
Old Feb 26, 2017 | 04:54 PM
Olds442redberet's Avatar
I have several I've pulled over the years. Each is marked with the engine / Transmission combination of the car they were pulled from.
Old Feb 26, 2017 | 06:03 PM
68442's Avatar
Do you have one that fits this application?
Old Feb 26, 2017 | 06:11 PM
Yes.
Old Feb 27, 2017 | 07:49 PM
72455442RA's Avatar
Hello
I accept your offer ....
the driveline has been wrapped in a moving blanket
and rolled in doubbble thick cardboard
ready to ship
thanks
Scott
Old Feb 28, 2017 | 04:54 PM
(1) 56" Center to Center
(2) 70 350/Th350 "O" rear, cutlass application
(3) One piece shaft
(4) Came out of a 1970 Cutlass Supreme
Old Feb 28, 2017 | 05:13 PM
72 Olds CS
i am far from any kind of expert but isnt that a 2 piece shaft ?
Old Feb 28, 2017 | 05:15 PM
No, it's a one piece shaft.
Old Feb 28, 2017 | 05:20 PM
Ok, explain two piece. The shaft doesn't slide in and out. It's solid.
Seriously, I am just trying to figure this stuff out.
Old Feb 28, 2017 | 05:42 PM
72 Olds CS
I thought and i could be wrong that your pics (specifcally #2) show 2 concentric shafts 1 inside another held together w vulcanized rubber.
the 1 piece shaft just has a gradual change in diameter, ill try to snap a pic of mine tomorrow to illustarte as i cant really make it out on any of the exisiting pics.
Old Feb 28, 2017 | 05:44 PM
72 Olds CS
if you look at 72 455s 2nd pic right around the 12.5" mark it show a diameter change in the shaft thats what i mean
edit added pic
Old Feb 28, 2017 | 06:09 PM
wr1970's Avatar
Your drive shaft is a two piece with the rubber to hold the parts together.
Old Feb 28, 2017 | 07:10 PM
oldspackrat's Avatar
Wasn't that to help with vibration dampening?
Old Feb 28, 2017 | 07:33 PM
wr1970's Avatar
You can assume what you want but it isn't a one piece. I have never had a vibration problem with a one piece that has been balanced. I am a drag racer can't have a bad drive shaft.
Old Feb 28, 2017 | 07:41 PM
What I meant was, wasn't the rubber in between there two pieces of the driveshaft to help with Driveline vibrations? I thought I had heard that somewhere along the line. Not arguing with you.
Old Feb 28, 2017 | 08:01 PM
wr1970's Avatar
I may be wrong on the rubber. I just know drag racers don't use that type of drive shaft because it is a two piece. Not arguing with you also.
Old Feb 28, 2017 | 08:04 PM
72 Olds CS
Scott thats what i thought as well, i thought the 1 peice was only for the manual trans but i am not certain at all.
Old Feb 28, 2017 | 08:06 PM
wr1970's Avatar
I am using stock drive shaft one piece in one of my race cars. The car is a automatic.
Old Feb 28, 2017 | 08:52 PM
marxjunk's Avatar
Olds442redberet yours is a two piece..it was used in low horse apps and the rubber is a dampener for rotational vibration..
its injected during the building of the drive shaft..and in hi horse apps, it just spins inside the tube when it hooks..very common in drive shaft buicks..
prob is lower horse can spin it too..and who knows when or if its ever spun...
Old Mar 1, 2017 | 04:20 AM
jcdynamic88's Avatar
i don't know about your 70s vintage cutlass/442 but a 65 442 had the solid shaft and a 65 cutlass had the 2 piece with rubber shaft
Old Mar 1, 2017 | 06:45 AM
wr1970's Avatar
I will add one more comment then i am done with this thread. I throw all of the two piece drive shafts in the junk pile to go to the scrapper. I hope the op gets what he wants.
Old Mar 1, 2017 | 09:01 AM
72455442RA's Avatar
thank you
shipping today at lunch break
smoooth transaction
thank you
Scott T
Old Mar 1, 2017 | 09:11 AM
Chesrown 67 OAI's Avatar
(3) One piece shaft
This IS a 2-piece shaft == slip end is set in rubber. Was made for automatic trans car.
Old Mar 1, 2017 | 09:14 AM
  #31
should have read further before i posted. Oyhers before me said same thing. Whats realy hard to find for a dragracer is a one-piece stock driveshaft for a TH400 application!! I raced with a 2-piecer and held my breath for 2 years until i found a 1-piece shaft to fit my 67 W30 TH400
Old Mar 1, 2017 | 09:45 AM
  #32
i can tell you first hand the 2 piece driveshafts don't like slicks and the torque of a 455,4 spd
Old Mar 1, 2017 | 06:44 PM
  #33
72455442RA's Avatar
driveline
very smooth transaction
very nice to deal with you .. I look forward to future chats ..
thank you
the driveline shipped fedex tonite
tracking will be pm'd to you next .. tracking wont be updated until the am..
ScottT
thanks Classic Olds !!!
onetogofast
Drivetrain/Differentials
Apr 8, 2009 06:27 AM
esisson
Apr 1, 2009 08:30 AM
ziff396
Dec 8, 2008 06:19 AM
J-(Chicago)
Sep 24, 2008 06:53 AM
ChrisM
Aug 12, 2008 02:22 PM
