Driver Side Fresh Air Vent Baffle - 66 442
I am in need of a fresh air baffle (I think that's what it is called) for the drivers side on my 66 442. This is the port that is behind the kick panel that let's fresh air in to the car. The original one broke and the oval door won't pivot at all.
Thanks,
Randy
Thanks,
Randy
I took a couple of pics of the outside of the baffle. It appears that there is a difference between the Dr & Pass sides. There is a lip that goes over the top which I assume holds some insulation in place, and one side is deeper than the other. The deeper side is toward the front of the car. If you have one like this, I will take it.
Thanks,
Randy
Thanks,
Randy
Here's one out of a 67 442 that I just pulled 10 minutes ago.. The cable needed a little oil, now it works just fine.
I see by looking at your pictures, the 66 year is different. My Bad.
I have one from a cheaper interior....no carpet... email me direct if you are interested. j.blusnavage@att.net
Looks like the baffle is different between '66 and '67. I guess I will need one out of a '66. Found out they are interchangeable from side to side, so if anyone has one it should work.
84oldsDelta88
20
January 12th, 2016 01:36 PM
December 10th, 2011 07:49 AM
